    no sound for splash videos - change omxplayer audio device to Alsa (Recalbox 6.0)
    sound splash videos omxplayer audio
    4587
    • teufelskrapfen
      teufelskrapfen last edited by
      Hi,
      I use a USB Audio device attached to my Pi 3b+ and it works fine for Emulationstation and emulators. However, I'm not getting sound from the Splash intros.
      I googled around on the issue and found that something similar was the case for retropie and they suggested to change omxplayer output to ALSA.
      I found the file S02Splash in the recalbox folder structure and wanted to change:
      omx_opt="--adev both --no-keys --layer=10000 --aspect-mode=fill"
      To:
      omx_opt="--adev alsa --no-keys --layer=10000 --aspect-mode=fill"
      However, I'm not using the correct syntax as on reboot the videos will now be skipped instead.
      I also tried "--adev alsa:hw:0,0" and "--adev alsa:hw:1,0" but its still not the right syntax...
      Does anyone know how to set the correct value here?
      Thanks and best
      Gregor
      Midgardsnake 1 Reply Last reply Reply Quote 0
      • ian57
        ian57 Staff last edited by
        @teufelskrapfen check your hardware with aplay -l and test use -o alsa:hw:1,0 to get sound on the second card first device
        teufelskrapfen 1 Reply Last reply Reply Quote 0
        • teufelskrapfen
          teufelskrapfen @ian57 last edited by teufelskrapfen
          @ian57 Thanks for your answer.
          It seems "aplay" is not present on my build but I just got a little further with my testing:
          I stopped emulationstation and started a video via an SSH connection:
          omxplayer --adev alsa:hw:0,0 /recalbox/system/resources/splash/recalboxintro.mp4
          Now the video plays fine on my Pi with sound … I also tried --adev alsa:hw:1,0 and then there was no sound … so hw:0,0 seems to be the correct device...
          If I add --adev alsa:hw:0,0 to S02Splash, the pi will boot with no splash intros. To confirm that my config file is not broken I changed the option back to --adev both and rebooted, then the splash intros will show up again without sound.
          • ian57
            @teufelskrapfen yes my bad, I forgot!!! we added some code to swith internal device and usb when present to put the USB audio as first device. So alsa:hw:0,0 is the right device when booted. Can you add --adev alsa:hw:1,0 to S02Splash and reboot
            If no sound, I think the video is played too early alsa is not ready yet. You'll need to move S02Splash to S13Splash for example... but the video will be played later
            • teufelskrapfen
              @ian57 Thanks I tried --adev alsa:hw:1,0 and got no sound, but the video was playing.
              I moved S02Splash to S13Splash with --adve alsa:hw:0,0 and it kind of works:
              The video plays now with sound after some some delay, but back in emulationstation the menu music would not work anymore.
              I also tried S03Splash, S08Splash, … and so on but the outcome would not improve. Either the intro splash would not play or it would play but then there was no Emulationstation music.
              • ian57
                @teufelskrapfen after ES is started, can you go the sound config menu and select another audio device, exit, return in the sound config menu and select you usb device again.
                • teufelskrapfen
                  @ian57 yes that works... as soon as I select a different audio device, the music plays again.
                  Also (without doing the above) when I start a game and return to Emulationstation, the music will play again as well.
                  • ian57
                    @teufelskrapfen ok, I think the problem comes from the delayed playing... the video is not finished when /etc/init.d/S26recalboxsystem is runned aand configure the sound for ES. As omxplayer uses the sound output, I think that the function rb_volume_configure ; rb_audio_configure do not finish succesfully... I think a workaround is to put audio configuration later for example in S99Custom
                    • teufelskrapfen
                      @ian57 Thanks I made backups of the files, then tried to copy / move the functions to S99Custom but didn't get it to work. Do you have a suggestion what parts of the script need to be copied/moved or what parts need to be present in S99Custom?
                      I restored my backups and also temporarily renamed S26recalboxsystem to S99recalboxsystem, but this also didnt work.
                      I was thinking of a workaround: maybe I can add a line to S13Splash that after the video has finished, the the output will be toggled to i.e. HDMI and immediately back to USB Audio.
                      • ian57
                        create the file /recalbox/share/system/custom.sh and put the following in it. try to run it through SSH before, to see if it works :
                        #!/bin/bash
                        systemsetting="recalbox_settings"
                        config_script=/recalbox/scripts/recalbox-config.sh
                        rb_volume_configure() {
                            settingsVolume="`$systemsetting -command load -key audio.volume`"
                            if [ "$settingsVolume" != "" ];then
                        	recallog "setting audio volume to $settingsVolume"
                                eval $config_script "volume" "$settingsVolume" 2>&1 | recallog
                            fi
                        rb_audio_configure() {
                            recallog "Restoring ALSA mixers configuration"
                            alsactl -f /recalbox/share/system/configs/asound.state restore
                            settingsAudio="`$systemsetting -command load -key audio.device`"
                            if [[ "$settingsAudio" == "" ]];then
                                settingsAudio="auto"
                            fi
                            recallog "setting audio to $settingsAudio"
                            eval $config_script "audio" "$settingsAudio" 2>&1 | recallog
                        ( rb_volume_configure ; rb_audio_configure ) &  # 1.0
                        • teufelskrapfen
                          @ian57 Thanks and sorry for my late answer.
                          For the script to run I had to change
                          to
                          systemsetting="python /usr/lib/python2.7/site-packages/configgen/settings/recalboxSettings.pyc"
                          I put S02Splash to S13Splash and added --adev alsa:hw:0,0
                          But I would only get sound from the splash intro but no music in Emulationstation.
                          • ian57
                            ian57 Staff @teufelskrapfen last edited by
                            @teufelskrapfen ok that's strange, did you test the S99custom alone to see if it is working. I made this thing in blind..; so perhaps I missed something.
                            • teufelskrapfen
                              @ian57 sorry havent got around testing it again but will try with S99custom this evening.
                              So I would:
                              • rename to S13Splash and add "--adev alsa:hw:0,0"
                              • copy/paste your text into S99custom
                              • do I need remove anything from S26recalboxsystem ?
                              • teufelskrapfen
                                teufelskrapfen last edited by teufelskrapfen
                                OK so I copy-pasted the text below into S99custom, but its the same behavior as before (splash screen has sound, emulationstation no sound). Do you know the command to trigger the output-device change? I.e. from USB Audio to HDMI … would like to try something
                                #!/bin/bash
                                test -e "/recalbox/share/system/custom.sh" && /recalbox/share/system/custom.sh $1
                                settingsVolume="$systemsetting -command load -key audio.volume"
                                fi
                                settingsAudio="$systemsetting -command load -key audio.device"
                                fi
                                • Midgardsnake
                                  Midgardsnake @teufelskrapfen last edited by
                                  @teufelskrapfen
                                  Hi,
                                  I had the same issue with my system and your post gave me an idea.
                                  In the latsest version of recalbox (6.1), I did this:
                                  • go to /etc/init.d
                                  • enter command: mount -o remount,rw /
                                  • open file splash03
                                  • change line 88 as follows:
                                  omx_opt="--adev local --no-keys --layer=10000 --aspect-mode=fill"
                                  • save
                                  Actually, "adev" must be followed by one these options: hdmi/local/both.
                                  Hope it might help.
