    Xbox Elite Controller?
    elite
    • liquidsnakeblue
      liquidsnakeblue last edited by
      Hello, Just got my Recalbox setup on my new Raspberry Pi and loaded it up with my roms.  When I plug in my Elite controller it causes the system to hang and eventually crash.  I would like to know if there is some way to get this working.   Thanks   Liquidsnakeblue
        Hello can you to active in recalbox.conf xbox driver ? look this https://github.com/recalbox/recalbox-os/wiki/recalbox.conf-(EN)
        controllers.xboxdrv.enabled=1
        • liquidsnakeblue
          I modified the recalbox.conf file as you suggested.  I will test when I get home in a few hours and am able to plug the controller in and report back.  Thank you for your prompt response. Liquidsnakeblue
          • liquidsnakeblue
            No luck, immediately freezes up when i plug it in.  After restarting the pi with the controller plugged in I end up with this screen:
