    Solved Bug ADF Multi Disks Amiberry
    adf multi disks amiberry
      voljega Banned last edited by voljega
      @Bkg2k
      Alors apparemment de mon côté aucun jeux en ADF avec multi disks ne se lance (retour direct à ES, les jeux en ADF monodisk marchent nickel ainsi que les WHDL)
      J'ai ça dans es_launch_stderr.log en sortie du jeu :
      Traceback (most recent call last):
        File "usr/lib/python2.7/site-packages/configgen/emulatorlauncher.py", line 268, in <module>
          exitcode = main(args)
        File "usr/lib/python2.7/site-packages/configgen/emulatorlauncher.py", line 182, in main
          command = generators[system.config['emulator']].generate(system, args.rom, playersControllers)
        File "/usr/lib/python2.7/site-packages/configgen/generators/amiberry/amiberryGenerator.py", line 223, in generate
          commandArray.extend(func(rom, subSystem, configFile))
        File "/usr/lib/python2.7/site-packages/configgen/generators/amiberry/amiberryGenerator.py", line 65, in getADFArguments
          files = glob.glob(nextDisk)
        File "/usr/lib/python2.7/glob.py", line 27, in glob
          return list(iglob(pathname))
        File "/usr/lib/python2.7/glob.py", line 63, in iglob
          for dirname in dirs:
        File "/usr/lib/python2.7/glob.py", line 64, in iglob
          for name in glob_in_dir(dirname, basename):
        File "/usr/lib/python2.7/glob.py", line 83, in glob1
          return fnmatch.filter(names, pattern)
        File "/usr/lib/python2.7/fnmatch.py", line 56, in filter
          _cache[pat] = re_pat = re.compile(res)
        File "/usr/lib/python2.7/re.py", line 194, in compile
          return _compile(pattern, flags)
        File "/usr/lib/python2.7/re.py", line 251, in _compile
          raise error, v # invalid expression
      sre_constants.error: bad character range
      Les noms des disks sont standards a priori (romset standard dont je n'ai pas changé les noms) :
      Valhalla and the Lord of Infinity (1994)(Vulcan)(Disk 1 of 6)(Boot)[cr DLM].adf
      Valhalla and the Lord of Infinity (1994)(Vulcan)(Disk 2 of 6)(Data).adf
      Valhalla and the Lord of Infinity (1994)(Vulcan)(Disk 3 of 6)(Level 1).adf
      Valhalla and the Lord of Infinity (1994)(Vulcan)(Disk 4 of 6)(Level 2)[cr FLT].adf
      Valhalla and the Lord of Infinity (1994)(Vulcan)(Disk 5 of 6)(Level 3)[cr DLM].adf
      Valhalla and the Lord of Infinity (1994)(Vulcan)(Disk 6 of 6)(Level 4)[cr FLT].adf
      Pistes à exclure directement :
      • j'ai tous les bios
      • pas de problème du côté de la gamelist
      • ADF monodisk et whdl marchent nickel
      • ce problème apparait sur a600 et a1200 en même temps
      (bon de toute façon en regardant le code, le problème semble être dans la recherche du pattern du nom du disk clairement)
      • Bkg2k
        Bkg2k Staff last edited by
        Je regarde ça asap
          voljega Banned @Bkg2k last edited by voljega
          @bkg2k le problème vient bien de glob.glob qui n'aime pas les [ et les ] (qu'il considère comme des caractères spéciaux, ceux ci sont énormément utilisés dans les noms de jeux adf, pour mentioner crack ou trainer par exemple
          à partir de python 3.4 il y a glob.escape qui permet de palier le problème mais pas en python 2.7 :s
          https://docs.python.org/fr/3.6/library/glob.html
          dès supression manuelle de ces crochets, les jeux multidisks sont loadés correctement (mais ce n'est bien sûr pas possible à l'échelle d'un romset)
            Bonjour @voljega
            bkg2k a résolu le problème , se sera dispo en 6.1
            https://gitlab.com/recalbox/recalbox/blob/master/RELEASE-NOTES.md#fixes
            • Fix Amiga multi-disk bug with [] characters
