    8bitdo snes 30 pro doesn't work well...
    8bitdo snes doesnt well
    1992
    • lfalbaneze
      lfalbaneze last edited by
      Hi hi,
      I have a 8bitdo snes 30 and
      I recently upgraded from version 4.0 to rb5.0.
      The control worked, but the L2 and R2 buttons do not ...
      Also the PsOne roms I had are not opening ...
      Do you know how I can solve this?
        OyyoDams Staff @lfalbaneze last edited by
        @lfalbaneze 5.0 doesn't exist. Please install Recalbox 6.0
        lfalbaneze 1 Reply Last reply Reply Quote 0
        • lfalbaneze
          lfalbaneze @OyyoDams last edited by
          @oyyodams I already installed version 6.0 but at the time of setting the L2 and R2 buttons, it does not recognize.
          To make sure it was not the control, I tested it on the PC and the buttons worked normally
            @lfalbaneze is it the SF30 pro controller ? And on which board ?
            • lfalbaneze
              @oyyodams said in 8bitdo snes 30 pro doesn't work well...:
              Yeah, Im using rasp pi3b
                @lfalbaneze try to upgrade the firmware of your pads. I do have the same pads, and they work without any issue on PI3.
                • lfalbaneze
                  @oyyodams ok, Ill try, if I still get problems, i talk again 🙂
                  ty
                  101.4k
