    black and white strips with HDMI only
    white strips hdmi
    • lbesnard
      lbesnard last edited by
      Hi
      I have some display issues with recalbox 6 on rpi3b
      It seems to mainly happens with N64 and Dreamcast, but i've seen the same behaviour at times on the shutdown page of recalbox v6
      A loaded game will look like this:
      However, there is no display issue if I use an hdmi to vga cable plugged into the same TV.
      Cheers,
      loz
        Zing Global moderator Translator @lbesnard last edited by
        @lbesnard said in black and white strips with HDMI only:
        Maybe this is a problem in videomode, which can be modified in the recalbox.conf file, but maybe it is the adapter HDMI to VGA that you are using.
        • lbesnard
          @zing said in black and white strips with HDMI only:
          Hi @Zing , thanks for your reply. However, the sentence you're quoting is out of context.
          I wrote:
          However, there is no display issue if "I use an hdmi to vga cable" plugged into the same TV.
          By this I meant that there is an issue with the HDMI to HDMI cable, but only for the dreamcast/n64 (so I guess a certain resolution)
          but no display issue with the HDMI to VGA cable.
            @lbesnard Sorry, it was a translation failure.
            Now I understand, but have you ever tried to modify the videomode as I mentioned?
