    Kodi crashes after library scan
    MediaCenter & Dualboot
    kodi crashes library scan
    4479
    • arcueid
      arcueid last edited by
      Hi,
      I've installed latest recalbox to my odroid Xu4.
      Works quite fine on emulation side, but my main suage is media center.
      After a library scan of musics or movies finished, kodi crashes when trying to go back to previous screen. And all other tries to load Kodi will fail (I see splash screen, then back to EmulatorStation).
      So I have to remove .kodi/userdata folder to get it working back, and scan again to get it crashing !
      I tried to enable some debug logs, but don't see anything relavant. Please take a look on them, maybe you will have a better idea : https://pastebin.com/CGdc5tmT
      Whatever I trying to pa**e result is the same, or whatever support is (network, external HDD).
      If someone has any idea to help me investigating this issue, I'll be glad to hear them šŸ˜‰
      Alex.
      • arcueid
        Hi I have some new with this library scan issue.
        I talked of this issue on Kodi official forum : https://forum.kodi.tv/showthread.php?tid=343694&pid=2854789
        I found that the crash comes from a kind of corrupted database.
        But this same database works on another system : https://uploadfiles.io/r8gjq3dl
        I'm looking to a distribution/sw version issue.
        • arcueid
          arcueid last edited by arcueid
          Above database works with 17.6 Kodi on Ubuntu 18 LTS with this version:
          17.6 Debian package version: 2:17.6+dfsg1-1ubuntu1 Media Center Kodi from Debian
          Copyright (C) 2005-2013 Team Kodi from Debian - http://kodi.tv
          Is there someone who can try using embedded RecalBox ?
          @moderators: this issue is probably not related to Kodi, but with distribution. Please move this thread as desired.
          • arcueid
            Hi all,
            I've made a trial of this database on my x86_64 laptop, and database works.
            Is there something wrong with odroid xu4 database parsing ? or lib version ?
            Please someone can give some tips for investigating this issue ?
            BR,
            Alex.
            • arcueid
              Hi,
              No news since almost 20 days.
              Is there anybody that can help me investigating this issue ?
              Should I need to recompile kodi with debug symbols ?
              Any help would be greatly appreciated !
              Alex.
              • arcueid
                I get an "Unrecognised instruction" in libcrypto:
                disInstr(arm): unhandled instruction: 0xEC510F1E
                cond=14(0xE) 27:20=197(0xC5) 4:4=1 3:0=14(0xE)
                ==3424== valgrind: Unrecognised instruction at address 0x7d37088.
                ==3424== at 0x7D37088: _armv7_tick (in /usr/lib/libcrypto.so.1.0.0)
                Probably called by kodi when accessing a pair of strings :
                ==3424== Process terminating with default action of signal 11 (SIGSEGV)
                ==3424== Access not within mapped region at address 0xBDB883C0
                ==3424== at 0x7330D4: std::pair<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > >::pair<char const (&) [5], char const (&) [66], void>(char const (&) [5], char const (&) [66]) (in /usr/lib/kodi/kodi.bin)
                Here is a full log : https://pastebin.com/hs5r43iF
                I'd like to get more clues to investigate but it seems I don't have symbols:
                *arcueid@Arcueid-VM:~/recalbox-odroidxu4/output/host/arm-buildroot-linux-gnueabihf/sysroot$ objdump -t usr/lib/kodi/kodi.bin
                usr/lib/kodi/kodi.bin: file format elf32-little
                SYMBOL TABLE:
                no symbols*
                However, I'm sure I enabled symbols and do not strip options in menuconfig :
                │ │ [] build packages with debugging symbols
                │ │ gcc debug level (debug level 2) --->
                strip target binaries
                │ │ gcc optimization level (optimization level 2) --->*
                The full config file : https://pastebin.com/PrLUUfPL
                Please I really need help on this topic, is there any developper comming here ?
                How should I report a bug on this distribution ?
                Alex.
                • arcueid
                  Starting program: /usr/lib/kodi/kodi.bin --standalone -fs
                  warning: Unable to find libthread_db matching inferior's thread library, thread debugging will not be available.
                  Program received signal SIGILL, Illegal instruction.
                  _armv7_tick () at armv4cpuid.S:94
                  94 armv4cpuid.S: No such file or directory.
                  (gdb) bt
                  #0 _armv7_tick () at armv4cpuid.S:94
                  #1 0xb3b17478 in OPENSSL_cpuid_setup () at armcap.c:157
                  #2 0xb6fdd608 in call_init.part () from /lib/ld-linux-armhf.so.3
                  Backtrace stopped: previous frame identical to this frame (corrupt stack?)
                  Can't go higher ... no dev can give me some tips ?
                  That's a shame ...
                  • arcueid
                    Last step I tried to remove all modules from Kodi (menuconfig), except alsa but even without mysql modules, I get a segfault on Kodi start.
                    Since there is no help here, I'm looking for help on recalbox's github and buildroot.
                    • lbr
                      lbr last edited by
                      Hi @arcueid
                      Have you had some help from anyone here or on github ? Because I have the exactly same problem, using a XU4 with the last recalbox build.
                      It crashes soon after starting library scan and going back to main menu...
                      • arcueid
                        Hi, no help so far.
                        Someone on discord reproduced the issue on Odroid-Xu4.
                        I updated to RB6.1 and found new issues :
                        • system sound is at 0% after start.
                        • kodi cannot play videos (they are freezing)
                        • no sound when playing music
                        • default sound card seems to be analog on kodi, while I'm using an AVR.
                        I posted a new thread here : https://forum.recalbox.com/topic/18866/odroid-xu4-kodi-with-rb6-1
                        • arcueid
                          Looks better with RB6.1 (I have to test more when I'll have time to update all libraries)
                          Since there is no Kodi update, was it an issue with kernel ? or some libraries ?
                          However, I cannot play any file since audio is not working 😢
                          • arcueid
                            I confirm library scanning is working back.
                            Some magic have been done in kernel/filesystem ...
                            Thanks.
                            • BLANKIAT
                              BLANKIAT Banned last edited by
                              This post is deleted!
                              BLANKIAT 1 Reply Last reply Reply Quote 0
                              • BLANKIAT
                                BLANKIAT Banned @BLANKIAT last edited by
                                Copyright Ā© 2021 recalbox.com
