    Odroid-XU4 Kodi with RB6.1
    MediaCenter & Dualboot
    odroid-xu4 kodi rb6.1
    1876
    • arcueid
      arcueid last edited by
      Hi,
      I updated to RB6.1 and found new issues :
      • system sound is at 0% after start.
      • kodi cannot play videos (they are freezing)
      • no sound when playing music
      • default sound card seems to be analog on kodi, while I'm using an AVR.
      BR,
      Alex.
      • arcueid
        arcueid last edited by arcueid
        After reboot, Kodi is able to play videos without sound.
        If I go to settings/audio, menu stucks for 20/30secs, then goes timeout.
        There I cannot select audio output (with is empty !).
        Any idea ?
        Some infos:
        • recalbox.conf:
          audio.device=auto
          audio.volume=100
          audio.bgmusic=1
        • /boot/config:
          <empty>
        • cat /proc/asound/cards:
          0 [OdroidXU4 ]: Odroid-XU4 - Odroid-XU4
          Odroid-XU4
        • grep audio /etc/retroarch.cfg | grep -v "#":
          <empty>
        • lsmod | grep snd
          <empty>
        • cat /etc/modules.conf
          uinput
          usbhid
        • amixer
          <empty>
        Looks like no driver is loaded ...
        • arcueid
          I tried this config, but there is still no sound on HDMI:
          • cat /boot/config.txt
            hdmi_drive=2
            dtparam=audio=on
            config_hdmi_boost=0
            hdmi_force_hotplug=1
          • hot22shot
            hot22shot last edited by
            Looks like a known bug (https://gitlab.com/recalbox/recalbox/issues/836) due to the kernel b*mp.
            No solution yet to my knowledge.
            xu4/Shapedmedia Alu Case/RB6.0
            pi3b+/Mechatronics Art Alu Case/RB6.0
            pi3b+/WaveShare GameHat/RB6.0
            • arcueid
              Thanks I'll follow it.
              There is 2 issues I think :
              • audio config not restored on boot (after manual setting, I get audio in games)
              • kodi audio not working at all (even after setting audio output device in RB)
              • dungtri
                dungtri last edited by dungtri
                Hello,
                On my xu4 with recalbox with update installed. I try to follow your instruction and change the asound.conf :
                pcm "hw:0,0".
                After a reboot, it just removed the menu stucks timeout.
                I still have no sound on kodi and video is freezing after few seconds.
                recalbox.conf:
                audio.device=auto (try hdmi as well)
                audio.volume=100
                audio.bgmusic=1
                I have all the same infos arcueid mention as bellow.
                On the kodi.log I got some error after trying to play a video on youtube:
                22:22:22.843 T:2435781600 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
                22:22:23.638 T:2951738336 ERROR: ActiveAE::FlushEngine - failed to flush
                22:22:24.049 T:2435781600 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
                22:22:28.638 T:2951738336 ERROR: Previous line repeats 3 times.
                22:22:28.638 T:2951738336 ERROR: ActiveAE::InitSink - failed to init
                22:22:28.638 T:2951738336 WARNING: CActiveAE::StateMachine - signal: 10 from port: OutputControlPort not handled for state: 1
                22:22:28.638 T:2951738336 WARNING: CActiveAE::StateMachine - signal: 11 from port: OutputControlPort not handled for state: 1
                22:22:28.874 T:2435781600 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
                22:22:29.142 T:2951738336 ERROR: ActiveAE DSP - Create - DSP input convert failed
                22:22:29.142 T:2951738336 ERROR: ActiveAE DSP - CreateDSPs - Creation of processing class failed
                22:22:30.080 T:2435781600 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
                The full log file is available here : https://nextcloud.dungtri.be/index.php/s/sogzeNJqSF68zcj
                On es_log.txt :
                [2019/11/25 22:21:00.109] (ERROR) : VolumeControl::init() - Failed to find mixer elements!
                [2019/11/25 22:21:00.129] (ERROR) : MUSIC Error - Unable to open SDLMixer audio: ALSA: Couldn't open audio device: Device or resource busy
                [2019/11/25 22:21:00.130] (ERROR) : /recalbox/share/system/.emulationstation/es_systems.cfg file does not exist!
                I would like to install aplay command to list and check if audio device is correct but I don't know how on rootbuild.
                Dung Tri.
