    Solved Can't upload Sega CD Romes
    cant upload sega romes
    2738
    • NostriK
      NostriK last edited by
      Recalbox installed on Raspberry Pi 3, when i'm trying to upload sega cd romes through web interface it is written that rom size can not be more than 256 Mb... For example earth worm Jim bin file - 394,6 MB, sonic cd bin file - 601,3 Mb, road rash bin file - 625,5 Mb e.t.c. What to do?
        Hello @NostriK
        try via share network or winscp software
        • NostriK
          Thx. The mentioned ☝🏻solved.
          Now can not start Sega cd games. Tried different ways.
          1. Upload earth worm Jim.bin and earth worm Jim.cue files - not working
          2. Upload earth worm Jim.iso file - not working
          3. Upload zip archive of both of 2 - not working
          Upload different bios for Sega CD - still not working...
          • olivierdroid92
            Try using an other game to check if it will works or not
              Hello
              • try another game
              • verify bios (md5)
              • change emulator and core
              • no uppcase in extension file (bin not BIN or CUE)
              • verify name in cue is the same as bin file.
              • Disabled rewind
              • NostriK
                Tried sonic cd, earth worm Jim, mortal combat, mikimania... 🤷🏼‍♂️ Not working, may be to try download Rome’s from another sources...
                • olivierdroid92
                  Is your BIOS ok ?
                  Check with Recalbox manager
                  • NostriK
                    Can you give me the link, where I can download proper BIOS??
                      On google search, you need to copy/paster md5 signature, or check in recalbox manager via web navigator
                      http://recalbox/bios
                      check this link too : https://forum.recalbox.com/topic/3646/forum-rules
                      • NostriK
                        With Sega CD - solved!
                        Now the same with 3do, trying to start games, black screen and nothing have happened... believe that the same as with Sega CD, need to find correct bios..
                          Zing Global moderator Translator @NostriK last edited by
                          @nostrik Of course without the BIOS you will have problems, but 3DO only works in Rpi3 if you overclock:
                          https://github.com/recalbox/recalbox-os/wiki/Board-Compatibility-(EN)
