    Why input configuration doesnt save on retroarch?
    input doesnt retroarch
    7968
    • 8bit_astronaut
      8bit_astronaut last edited by
      why the configuration in retroarch doesnt save? I selected configuration per core, mapped a personal input for only that core, and save it, but when i restart the game, all the configurations are gone!!!! This is gettting me stressed please help with words, i dont understand those links 😕
      • ivwshane
        ivwshane last edited by
        Do you also have "configuration save on exit" set to yes?
        • 8bit_astronaut
          i already found the way, but had to use a extfs program to manually edit the configfile
          • hanker
            hanker last edited by
            Hello from Germany!
            Please excuse me to relive this thread.
            I have the same problem with snes9x_next (at least that's what I tried to configure).
            Yoshi's Island and Kirby Super Star do not like the Multitap, so you have to deactivate it. I'm using the advice from https://github.com/recalbox/recalbox-os/wiki/Play-from-3-to-4-players-to-SNES-(EN) to deactivate Multitap, which is enabled by default, but this option simple doesn't "stick".
            Can you help me? Perhaps by pointing me to the right config file so I can edit it manually?
            Thanks in advance
            René
              Substring @hanker last edited by
              @hanker such games require you cange the core to catsfc (or disabele multitap in retroarch, but ... a little more complicated). Go to your game, press select, edit metada, emulator to libretro, core to catsfc, and save
              There have been numerous answers about the multitap problem ...
              • hanker
                @Substring I know of the "change core" solution, but still: Why isn't it possible to save the settings of Input 2 in retroarch?
                Whenever I change it from "Multitap" to "SNES Joypad" and restart and resume the game, it works perfectly. But when I return to Emulationstation and back to the game, Input 2 is again "Multitap". Yes, I've turned "Save Configuration On Exit" to "ON" before.
                Also, after I have changed "Save Configuration On Exit" to "ON", it stays that way, even after setting it to "OFF" again later. Had to edit manually the retroarchcustom.cfg to turn it to "OFF" again...
                Both seem to be a bug, even if there's a workaround...
                Ideas anyone?
