    RecalBox on "Arcade1up" cabinets
    Community projects
    recalbox arcade1up cabinets
    • HapHzrd
      HapHzrd last edited by
      Is anyone using RecalBox on an Arcade1up cabinet? I am having trouble getting it to display in the appropriate aspect ratio.
      The Arcade1up horizontal version uses a 5/4, 1280x1024 screen,
      and the vertical version uses a 4/5, 1024x1280 (of course).
      Regarding playing on the horizontal Arcade1up…
      In the Main Menu: Game Settings: Video Ratio:
      • the AUTO setting doesn’t seem to work.
      • the 16/9 setting seem to display the horizontal games properly, but stretches the vertical games.
      Regarding playing on the vertical Arcade1up…
      • in the Main Menu: Game Settings: Video Ratio:
      • there does not seem to be settings for vertical aspects. Examples 9/16, 3:4, 4/5, etc.
      • Am I missing it somewhere?
      Also, is it possible to set a specific aspect ratio per game? I can do this in the RetroArch menu for MAME and FBA, which works for the current game session, but I think a global setting resets it everytime.
      Thanks in advance.
      • zetof
        zetof last edited by
        Did you try :
        global.videomode=DMT 35 HDMI
        In recalbox.conf ?
        HapHzrd 2 Replies Last reply Reply Quote 1
        • HapHzrd
          HapHzrd @zetof last edited by
          @zetof, thanks for the reply.
          I have not tried that. That will set the system to "1280x1024@60"? I will give it a try tonight.
          Is there an equivalent syntax for a vertical mode "1024x1280"?
          Thanks, again.
          • HapHzrd
            @zetof, this worked! Many thanks, my friend.
            I searched for something similar but could not find what I was looking for.
