    Solved Does RC6 run on the RP3A+ ?
    does rc6 run rp3a
    • Fudoh
      Fudoh last edited by
      I don't see the A+ plus listed in the official support docs, but since the RP3A+ has been out for a few months now, I'm wondering if RC6 can be installed on a A+ based system ?
      The RP3A+'s is basically a RP3 without the network port and RAM cut into half, but it's tiny and makes a great board for really small cases.
      So, is this supported ?
      Thank you!
      • olivierdroid92
        No.
        You can have a look here :
        https://github.com/recalbox/recalbox-os/wiki/Board-Compatibility-(EN)
