    Unsolved Moonlight on Recalbox 6.0 Not Working
    moonlight recalbox 6.0
    11
    32
    11389
    • miso117
      miso117 last edited by
      Hello all! I set up Moonlight on Recalbox 6,0 and paired without an issue, generated the gameslist without an issue, and the Moonlight menu now appears in ES. When I go to launch a game or Steam, it goes to the loading page and fails back to ES. Nothing happens on the PC side... I pop in my old SD card with the previous version of Recalbox (4.0) and it loads up without issue.
      Thoughts? Anyone seeing the same thing?
      • mbaudouin
        mbaudouin last edited by
        Hi, same PB for me.
        After select game, it return EmulationStation after 2seconds without errors.
        • Zemus
          Zemus last edited by Zemus
          I have the same Problem.
          Under ssh i can establish a connection if i just use "moonlight" as a command. But if i paste the command used by the es-ui i get the following error:
          Command: # python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc -p1index 0 -p1guid 050000007e0500000920000001000000 -p1name "Pro Controller" -p1nbaxes 4 -p1devicepath /dev/input/event0 -system moonlight -rom /recalbox/share/roms/moonlight/1088017781_.moonlight -emulator default -core default -ratio auto
          Traceback (most recent call last):
          File "usr/lib/python2.7/site-packages/configgen/emulatorlauncher.py", line 268, in <module>
          exitcode = main(args)
          File "usr/lib/python2.7/site-packages/configgen/emulatorlauncher.py", line 182, in main
          command = generators[system.config['emulator']].generate(system, args.rom, playersControllers)
          File "/usr/lib/python2.7/site-packages/configgen/generators/moonlight/moonlightGenerator.py", line 15, in generate
          configFile = controllersConfig.generateSDLGameDBAllControllers(playersControllers, outputFile)
          AttributeError: 'module' object has no attribute 'generateSDLGameDBAllControllers'
          So the log shows me:
          [2019/04/20 22:19:32.494] (WARN!) : ...launch terminated with nonzero exit code 256!
          • kdash9999
            kdash9999 last edited by
            Same here ... if someone can help 😞
            cat /recalbox/share/system/logs/es_launch_stderr.log
            File "usr/lib/python2.7/site-packages/configgen/emulatorlauncher.py", line 268 , in <module>
            File "usr/lib/python2.7/site-packages/configgen/emulatorlauncher.py", line 182 , in main
            lmerckx 1 Reply Last reply Reply Quote 0
            • lmerckx
              lmerckx @kdash9999 last edited by
              @kdash9999
              I believe I know the problem. I will check to solve that this week-end.
              Recalbox 9.1 on RPI 4, SSD 250Gb, 2 Logitech F710, Nespi4case
              Contributions for DosBox, ScummVM, ResidualVM, Daphne (Hypseus)
              kdash9999 1 Reply Last reply Reply Quote 0
              • kdash9999
                kdash9999 @lmerckx last edited by
                @lmerckx said in Moonlight on Recalbox 6.0 Not Working:
                Thanks
                • lmerckx
                  Ok, I've just made a small adaptation and now it works ... almost.
                  Moonlight starts, the game starts on my computer but the screen remains black on Recalbox.
                  I've no time to look further now but I'll test again on the week-end.
                  • lmerckx
                    There was another problem ...
                    The current version of MoonLight (2.4.7) is not compatible with recent versions of GFE.
                    But it has been patched and it works, even if it is not a stable version.
                    So, I will change that too !
                    bankovse 1 Reply Last reply Reply Quote 1
                    • lmerckx
                      This two problems should be solved in version 6.1.
                      Some corrections and updates have been done for this future release.
                      kdash9999 1 Reply Last reply Reply Quote 3
                      • mbaudouin
                        Big thanks !
                        I look forward to the next version.
                        • kdash9999
                          @lmerckx merci bien 😉 vivement la 6.1 du coup, tu penses avoir des infos sur une date approximative ? En tout cas merci pour le boulot que vous faites !! Elle assure cette recalbox 🙂
                            acris last edited by OyyoDams
                            Aucune date ne sera communiqué.
                            • kdash9999
                              kdash9999 @acris last edited by
                              @acris ok ok encore merci
                              • kdash9999
                                @lmerckx if possible, could you give us the steps to resolve it by ourselves ? Thanks in advance
                                • lmerckx
                                  @kdash9999 I could but are you ready to recompile the Recalbox project ?
                                  Because you will need to do it ...
                                  The steps to follow are listed in this page: https://gitlab.com/recalbox/recalbox
                                  • kdash9999
                                    @lmerckx didn't think it was something like this, i'll wait thx
                                    • bankovse
                                      bankovse @lmerckx last edited by
                                      @lmerckx could downgrade gfe help with this?
                                      • lmerckx
                                        @bankovse I'm not sure to understand your question.
                                        But I was unable to downgrade GFE on my computer. The only solution I found was to upgrade Moonlight.
                                        bankovse 1 Reply Last reply Reply Quote 0
                                        • bankovse
                                          @lmerckx I installed version 3.10 of GFE, but it did not help.
                                          It still crashes a few seconds after launch, back to the main menu
                                          • micky49
                                            micky49 last edited by
                                            Hi,
                                            Sorry for my english.
                                            The moonlight problem is known. Is there a method for Moonlight to work?
                                            Is an update planned soon to fix this problem?
                                            Thank you.
