    Kodi 17 IR Remote
    MediaCenter & Dualboot
    kodi remote
    2476
    • DiZ91
      DiZ91 last edited by
      Hey. I can’t set up IR Remote on a new version of Recalbox. In the latest version for 2018, everything worked fine
      • fonzman
        fonzman last edited by fonzman
        I also have a problem with my IR remote.
        I made all the preparations (which work fine in Recalbox 4.1 with Kodi 16.1):
        dtoverlay=lirc-rpi in /boot/config.txt is active
        /recalbox/share/system/.config/lirc/lircd.conf exists
        irw recognizes my IR inputs
        /recalbox/share/system/.kodi/userdata/keymaps/remote.xml is the default from Kodi 17.6
        /recalbox/share/system/.kodi/userdata/Lircmap.xml did not change since upgrade (and thus should work)
        Still, Kodi ignores my IR remote. Is it possible that the Kodi-Version on 6.0 DragonBlaze was compiled without IR support?
        • fonzman
          Just analyzed my kodi.log from 16.1 vs. 17.6 and found this:
          in Kodi 16.1 this is present:
          14:03:48 T:1836053472 INFO: LIRC Process: using: /var/run/lirc/lircd
          14:03:48 T:1836053472 INFO: LIRC Connect: successfully started
          ...but missing from Kodi 17.6
          Seems 17.6 is actually missing/not looking for the LIRC/IR driver!
            paradadf Staff @fonzman last edited by
            @fonzman remote.xml is, afaik, only responsible for the cec mapping, not lirc. I recently did a MR deleting that custom xml file completely as it will easily get outdated between releases.
            Thi instructions might be outdated though:
            https://github.com/recalbox/recalbox-os/wiki/Infra-red-remote-control-on-the-Recalbox-(EN)
            Please check in the kodi wiki or tutorials which files should be addressed and compare with the one in recalbox.
            • fonzman
              Thank you paradadf, I know this faq.
              I followed it some time ago when I configured lirc for Kodi 15 (back with recalbox 3.x or 4.0?), and made updates to Kodi 16.2 (with recalbox 4.1).
              As I said, buildroot OS is recognizing my IR inputs also in Recalbox 6.0.
              See this from my current setup:
              irw
              0000000077e1d0e4 00 KEY_UP Appleremote
              0000000077e1d0e4 01 KEY_UP Appleremote
              0000000077e1b0e4 00 KEY_DOWN Appleremote
              0000000077e1b0e4 01 KEY_DOWN Appleremote
              0000000077e1e0e4 00 KEY_RIGHT Appleremote
              0000000077e1e0e4 01 KEY_RIGHT Appleremote
              0000000077e110e4 00 KEY_LEFT Appleremote
              0000000077e110e4 01 KEY_LEFT Appleremote
              0000000077e110e4 02 KEY_LEFT Appleremote
              0000000077e120e4 00 KEY_PLAY Appleremote
              0000000077e120e4 01 KEY_PLAY Appleremote
              0000000077e140e4 00 KEY_MENU Appleremote
              0000000077e140e4 01 KEY_MENU Appleremote
              only in Kodi no button presses are registered. And as I wrote in my last post, Kodi 16.2 (on Recalbox 4.1) has these 2 lines in the kodi.log:
              But they are missing from the kodi.log in Kodi 17.6 under Recalbox 6.0!
              For me it seems Kodi starts without LIRC support. Can I somehow enable it? What does Recalbox exactly do when I press "Start Kodi" in the emulationstation-menu?
              SOLVED!!
              On Recalbox 6.0 Kodi 17.6 does ACTUALLY start without IR support! To rectify this, follow these steps:
              • ssh to your recalbox
              • make your system writeable with mount -o remount,rw /
              • edit line 49 in /recalbox/scripts/kodilauncher.sh to look like this (changes are bold):
                LD_LIBRARY_PATH="/usr/lib/mysql" /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /var/run/lirc/lircd
              • restart
                paradadf Staff @fonzman last edited by paradadf
                @fonzman would you mind creating a Merge Request (MR) on gitlab to add those missing parameters by default?
                https://gitlab.com/recalbox/recalbox/blob/master/board/recalbox/fsoverlay/recalbox/scripts/kodilauncher.sh#L49
                fonzman 1 Reply Last reply Reply Quote 0
                • fonzman
                  fonzman @paradadf last edited by
                  @paradadf said in Kodi 17 IR Remote:
                  done
                    @fonzman great, thank you.
