    Hyperpixel 4.0 Display
    Controller/GPIO/USB
    hyperpixel 4.0 display
    • netway
      netway last edited by
      Hallo,
      kann mir vielleicht jemand bei der Installation eines Hyperpixel 4.0 Displays helfen?
      Unter SSH bekomme ich nur die Anweisung mich als Benutzer mit sudo Rechten anzumelden?
      Manuel die config.txt anzupassen hat auch nicht geholfe.
      OyyoDams glook 2 Replies Last reply Reply Quote 0
        OyyoDams Staff @netway last edited by
        @netway Recalbox is NOT Raspbian, you cannot install it like that. Recalbox is an operating system built from scratch so this kind of script won't work. If you have very good linux skills, you can try to find if there is a way to compile Recalbox with the sources of this product and help us.
        • glook
          glook @netway last edited by glook
          @netway
          hi, sorry for the english answer but my deutsch is bad
          the driver to use is hyperpixel4 (and not hyperpixel)
          have a look on :
          https://github.com/pimoroni/hyperpixel4
          how to :
          • compile hyperpixel4.dts (if you have raspbian) or search hyperpixel4.dtbo on the web
          • copy hyperpixel4.dtbo to boot/overlays/ on recalbox
          • add at the bottom of config.txt file :
          # HyperPixel LCD Settings
          dtoverlay=hyperpixel4
          overscan_left=0
          overscan_right=0
          overscan_top=0
          overscan_bottom=0
          framebuffer_width=800
          framebuffer_height=480
          enable_dpi_lcd=1
          display_default_lcd=1
          dpi_group=2
          dpi_mode=87
          dpi_output_format=0x7f216
          display_rotate=3
          hdmi_timings=480 0 10 16 59 800 0 15 113 15 0 0 0 60 0 32000000 6
          • copy the hyperpixel4-init who is in /dist directory of github link to /usr/bin/ of recalbox
          • at least, you must execute hyperpixel4-init to initialize the screen at recalbox startup, for example you can add the hyperpixel4-init command at the top of /etc/init.d/S02splash or create a S02hyperpixel script with this command inside
          you must remount the recalbox system with rw access to do the 2 last items
          reboot and enjoy !
          the french thread is here :
          https://forum.recalbox.com/topic/17854/ecran-hyperpixel-4-pouces
          GlOoK
