    Wifi problem with Recalbox 6 on PC 64 Bits
    wifi recalbox bits
    • Dekiste
      Dekiste last edited by
      Hello,
      I'm new in this forum.
      I am using Recalbox on PC, 64 Bits Ver.: 18.07.13. With that version, the wifi connection works well. I can activate and deactivate it, I can see a list of available connections when I go into "SSID WIFI" and I can connect to the wifi without problems.
      Yesterday I downloaded the newest version, 6.0-Dragoinblaze and the wifi connection is not working. Nothing happens if I activate or deactivate it, I cannot see a list of available connections, nothing.
      I tried the following with no success:
      • Another wifi-adapter (the original Raspberry Pi wifi adapter)
      • I modified the Recalbox.config file
      • Another hardware
      • I flashed it with Balena Etcher, USB-Stick and HDD
      • I tried also with RC1, RC2 and RC3
      • Restart the system several times
      • I looked for information to try to solve this problem
      Today I downloaded the version for the Raspberry Pi and it works fine!, so I think it must be a problem with the 64Bit-PC-Version.
      Could you please check this?
      Many thanks in advance, you're making a great job!
      Greetings from Germany,
      José.
        OyyoDams Staff @Dekiste last edited by
        @dekiste hi,
        Issue known and opened: https://gitlab.com/recalbox/recalbox/issues/565
        • Dekiste
          Hi OyyoDams,
          thank you for your quick response!
          Kind regards,
          José.
