    Solved Update 18.07.13 to v6.0?Am I missing something ?
    update 18.07.13 v6.0am missing something
    10
    23
    10760
    • mritacco
      mritacco last edited by
      Hi trying to Update 18.07.13 to v6.0?Am I missing something ?
      • olivierdroid92
        not possible to update.
        you need to start with fresh install
        mritacco 1 Reply Last reply Reply Quote 0
        • mritacco
          mritacco @olivierdroid92 last edited by
          @olivierdroid92 ok thanks ! Because it’s a much older version ? Or just a totally different one ?
            @mritacco
            both
            • mattmame
              mattmame last edited by
              That sucks!
              Need to perform a fresh install to be up to date is a pity since we have 18.07.13 version !
              Si vous avez aimé mon post ou s’il a pu vous aider, mettez moi une petite flèche vers le haut.
                OyyoDams Staff @mattmame last edited by
                @mattmame hey, we've announced this for many weeks!
                1 Reply Last reply Reply Quote 3
                • Maniaczek
                  Maniaczek last edited by Maniaczek
                  Hi!
                  I understand that i have to do a fresh install but is there any chance to do it without losing any roms?
                  Do i have to copy them to pc?
                  Or is there posibility to copy all roms to external usb drive or something like this without online?
                  loak 1 Reply Last reply Reply Quote 1
                  • loak
                    loak @Maniaczek last edited by loak
                    @maniaczek, assuming that your roms are on the SD card, you have to connect to your Recalbox thru your home network and save bios, roms and saves folders on your computer.
                    Do a fresh install of Recalbox and visit the wiki page https://github.com/recalbox/recalbox-os/wiki/Use-an-external-usb-storage-device-on-recalbox-(EN) (the part called Setup Recalbox to use your USB key may do the trick)
                    Once the usb storage has been created, copy back your bios, saves and roms only (without gamelist.xml and pictures folders)
                    Scrap your roms from your computer and the usb key plugged in with an external soft scrapper (Skraper for example). The old gamelist.xml are not compatible anymore and may lead to black screen at the start of your new recalbox.
                    Patience and calm will lead you to the resolution of your problem.
                    Recalbox last update
                    mattmame 1 Reply Last reply Reply Quote 0
                    • mattmame
                      Even windows can perform major updates.
                      It’s so incredible !
                      OyyoDams nightlybuilds 2 Replies Last reply Reply Quote -4
                        OyyoDams Staff @mattmame last edited by OyyoDams
                        @mattmame if you're here just to post messages like that, you can take a drink and stop that immediately. That's just a lack of respect regarding the many hours we've all spent for free for months on Recalbox. We're all volunteers, not paid, we all have a life, a real job, childrens, and we're all doing our best to make this operating system even than better. It seems you know NOTHING about computing and development. I won't even try to explain you why this update is basically impossible, because I'm juste tired reading this kind of stupid messages. So the next message I see from you like that, you'll be fired from the forum. That's simple.
                        • mattmame
                          I know you and developers work a lot.
                          If it was windows developments I could help you but I’m not Linux friendly.
                          Just to explain, I am a computer specialist.
                          The problem: I have Recalbox on a dedicated computer. A fresh install on a computer is not as simple as on a raspberry.
                          • save many folders from network on my nas
                          • open computer
                          • take hard drive
                          • put the hard drive in a dock
                          • burn the image using etcher
                          • put the hard drive in the computer
                          • restore folders from network
                          • scrap about 10000 games (because the image folder is renamed in the 6.0 version) that will take a while
                            You can fire me if you want to but can you understand how difficult an update might be for end users ?
                            Some won’t update due to how difficult it is.
                            If mame and fba are updated some of users games won’t work anymore.
                            Change may be difficult for developers but EVEN for users.
                            I want to continue Recalbox experience because it’s such a wonderful project and I thank developers for their great work.
                            I don’t want this project dies because users think it’s to hard to have an up to date version and as a consequence abandon Recalbox.
                            Thx for reading me
                          • Bkg2k
                            Bkg2k Staff last edited by
                            There is NO NEED of rescrapping. As long as you save BOTH gamelist.xml and their corresponding media folders.
                            • Bkg2k
                              It's not that hard to do a fresh install. Even on WINDOWS it is NOT recommended to update to major OS versions. Everytime we did it, we ran into (serious or not) issues.
                              That's the same here. We did our best to enable the old 18.07.13 version being able to update. But that was so risky we decided NOT TO DO SO. And that was a reasonnable decision, because crashing dozens of thousands of Recalbox is A LOT MORE annoying than making a fresh install mandatory even if you think it's that painfull.
                              We do our best every day to make recalbox better. Forcing everyone to make a fresh install is not a matter of laziness, it's a matter of wisdom.
                              mattmame 1 Reply Last reply Reply Quote 2
                              • mattmame
                                mattmame @loak last edited by
                                @loak said in Update 18.07.13 to v6.0?Am I missing something ?:
                                @Bkg2k ok but in this message it is written former gamelist.xml and downloaded images folder are not supported
                                What do I have to do ?
                                Can I put my images in another folder and edit xml and replace all downloaded_images by the new folder name ?
                                • Bkg2k
                                  Bkg2k Staff @mattmame last edited by
                                  @mattmame You can move your gamelist.xml and media folders (whatever they are named) as long as you did not selected specific emulators for one or more games (using "edit metadata").
                                  If you did such changes, just open your gamelist.xml and remove <emulator> and <core> tags.
                                  • loak
                                    loak last edited by loak
                                    Maybe I did too much zeal for the scrap part but this problem often comes up in the forum.
                                    • mattmame
                                      mattmame @Bkg2k last edited by
                                      @bkg2k thank you very much.
                                      Explained like that is really better.
                                      For me, I work as a computer specialist in an hospital that counts about 6000 computers and hundreds of servers.
                                      May you understand why it’s so important for me not to disturb medical activity and preserve patient when an update is made.
                                      So in my position, making a fresh install is really impossible and we always work to make updates work.
                                      I still thank you for your work and your patience
                                      • nightlybuilds
                                        nightlybuilds @mattmame last edited by
                                        @mattmame I too found that the inadequate upgrade path was more troublesome than helpful. As a fellow software engineer, upgrade paths are always the top concern to ensure customer satisfaction.
                                        mattmame 1 Reply Last reply Reply Quote 1
                                        • mattmame
                                          mattmame @nightlybuilds last edited by
                                          @nightlybuilds thanks. May I be helpful for you one day
                                          • rinkymehra
                                            rinkymehra last edited by
                                            get-9apps.com/index/ & get-cartoonhd.com :)
