    RecalboxOS v3.3.0-beta17 Raspberry Pi Zero files release.
    v3.3.0-beta17 zero release
    3135
    • jose-manuel-perez
      jose-manuel-perez last edited by
      When can we enjoy Recalbox in our Raspberry Pi  Zero?
        Hello when someone will gift rpi zero to digitalumberjack 😛 i dont know but github issue is open : https://github.com/recalbox/recalbox-os/issues/503
        • jose-manuel-perez
          No need a raspberry pi zero, you only need a raspberry 1 (B + or A +) digitalumberjack sure you have at home. A recalbox that works well in those old raspberry, also works on a Raspberry Pi Zero, that easy.   I hate that you go one step behind rivals in some areas. Thanks Acris
            Dude, we all believe the rpi1 build should work. But as long as no one can test that, we can't state it works. We just can't advertise a supported system whereas we haven't even tested it. But trust me, we are all on the starting blocks to get a pi zero 🙂
            • digitaLumberjack
              The recalbox is already 100% compatible with the rpi1 @jose-manuel-perez but as you might understand it does not means it's compatible with rpi0. And as we have feedback talking about installation failures on rpi0, i really need a rpi0 to test that. So yes we need a rpi0, and i can't find one for now.
              • lmacky
                lmacky last edited by
                I currently have the zero and have some experience with recalbox from several months ago. I have had mixed luck using the boot.tar.xz file from raspbian in noobs 1.5.0 copied into the recalboxos-rpi1 os folder and then installing it as normal with noobs. it now starts to boot on the zero and shows the emulationstation logo and then I just get a blank screen. I will continue trying to get it working tomorrow but was wondering if your able to provide an updated boot file I could try as I believe it is just a simple update required to get it working on the zero: https://www.raspberrypi.org/forums/viewtopic.php?t=58151 if you look at the 3rd post it says to use the rpi-update command to fix an image but this is omitted from recalbox. as I say ill carry on fiddling and provide an update if I manage to get it working. sorry about this poorly formatted post 😄 Les
                • lmacky
                  After several failed attempts I feel my grasp of Linux is just not strong enough for this. apparently it requires the newest kernel/boot files but I am unsure which these are.
