    Atari st games won’t run
    Emulator Arcade/PC/Console
    atari st
    2209
    • Bas
      Bas last edited by
      Hi,
      Fresh recalbox install with some Atari st .st files.
      When trying to run screen comes direct back in recalmenu.
      What am I doing wrong?
      I’ve put TOS.img in bios....... seem to have red that some where.
      What files should go where?
      Much appreciated.
        Zing Global moderator Translator @Bas last edited by
        @bas Check in the recalbox manager if the BIOS is correct, and remember that the system is case sensitive, sometimes it is just rename the file name, maybe this is the case (the same is valid for the extension if the correct one is "tos.img", the system will not recognize "TOS.img" nor even "tos.IMG")
        Bas 1 Reply Last reply Reply Quote 0
        • Bas
          Bas @Zing last edited by
          @zing Will try that !
          🙂 seems plausibel !
          Than tackle the neogeo.
          Everything running on final burn alpha but under the neogeo won’t.
          There’s supposed to be a neogeo.zip with 1.454kb in size. If it is case sensitive haven’t found it (yet).
          Any tips on neogeo?
            @bas Neogeo needs the bios neogeo.zip to be in the same folder as the ROMs (ie needs a copy of the neogeo.zip BIOS inside the NEOGEO folder)
            • Bas
              @zing think it’s case sensitive with capitals or not. I already tried putting the file in bios and game folder ... just won’t do.
              Then again I can’t find the file with exact 1.454 kb. I have found a neogeo.zip but not sure it’s the right one. Do you know wich works and where to be found? Just saw a vid on unibios, gonna try that tonight.
              Thanks
                paradadf Staff @Bas last edited by
                @bas do not ask again about where to find copyrighted content please.
                • Bas
                  Bas @paradadf last edited by
                  @paradadf said in Atari st games won’t run:
                  Sorry forgot that.
