    Load saves form other emulator
    saves form
    2170
    • zsche
      zsche last edited by
      Hello, I'm trying to load a save from an n64 emulator to my recalbox but it doesn't work. It is possible to play my n64 game on recalbox starting from the saves i did on an emulator on pc?
      PS Thank and sorry for my bad english
        Zing Global moderator Translator @zsche last edited by
        @zsche Sorry, but this is not exactly a doubt about Recalbox ... Search google by checking the file extension you have (for example: .xxx), and which file extension is recognized by Recalbox (for example:. yyy), and put the word "convert" at the beginning of the search (for example: Convert .xxx to .yyy).
        zsche 1 Reply Last reply Reply Quote 0
        • zsche
          zsche @Zing last edited by zsche
          @zing thats exactly what i did but i didn't find any converter, the n64 emulator on pc saves .dat and .pj files and recalbox saves .eep and .st0, i tryed to rename or replace files but it doesn't work.
          Is it possible to do that by loading on recalbox the emulator I used on pc (for compatibility)?
          OyyoDams barbudreadmon 2 Replies Last reply Reply Quote 0
            OyyoDams Staff @zsche last edited by
            @zsche sorry but it won't work like that! You can't just rename the files, cross your fingers and think it'll work by magic. @Zing is right, you might try to find a way to convert your savegames to a format compatible by emulators used on Recalbox, if it's possible (I don't know).
            • barbudreadmon
              barbudreadmon @zsche last edited by
              @zsche http://www.emutalk.net/threads/55054-Convert-from-PJ64-to-Mupen64
              Libretro developper :
              • FBAlpha FBNeo (Arcade)
              • Kronos (Sega Saturn/ST-V)
              • YabaSanshiro (Sega Saturn)
              • zsche
                OK thanks guys i finally did!! I saved in game and past the .eep file
