    My msx doesn't work
    Emulator Arcade/PC/Console
    msx doesnt
    4213
    • Storm
      Storm last edited by
      Hello everyone,
      Since I made the update 18.07.13, my msx does not work with a fresh install or the beta. I tested with the emulator fmsx and bluemsx. Via bluemsx it comes back to the selection screen of msx games and by fsmx I have a black screen. What do you recommend me ?
        paradadf Staff @Storm last edited by
        @storm have you added the required bios files?
        Storm 1 Reply Last reply Reply Quote 0
        • Storm
          Storm @paradadf last edited by
          @paradadf Thanks for your help
          I downloaded the BlueMSX standalone version, available to this adresse : http://bluemsx.msxblue.com/rel_download/blueMSXv282full.zip
          Then extract the "Databases" and "Machines" folders and add them to the bios folder of my recalbox
            OyyoDams Staff @Storm last edited by
            @storm
            ## BIOS ##
            - BlueMSX (EMULATOR MSX BY DEFAULT) :
            You must download the BlueMSX standalone version, available to this adresse : http://bluemsx.msxblue.com/rel_download/blueMSXv282full.zip
            Then extract the "Databases" and "Machines" folders and add them to the bios folder of your recalbox.
            - FMSX :
            You must have these following files, available with fmsx distribution, in the bios folder of your recalbox :
            CARTS.SHA
            CYRILLIC.FNT
            DISK.ROM
            FMPAC.ROM
            FMPAC16.ROM
            ITALIC.FNT
            KANJI.ROM
            MSX.ROM
            MSX2.ROM
            MSX2EXT.ROM
            MSX2P.ROM
            MSX2PEXT.ROM
            MSXDOS2.ROM
            PAINTER.ROM
            RS232.ROM
            • Storm
              Storm @OyyoDams last edited by Storm
              @oyyodams Cool, Thank you very much! I downloaded fsmx @ https://github.com/libretro/fmsx-libretro and I put the files you told me to the root of the bios folder. That works but the keyboard it's necessary ?
              Bluemsx doesn't work.
              • samba
                samba last edited by
                @Storm Have you been able to fix this issue? I am experiencing a quite similar issue, even on the latest Recalbox 6. Can you tell me how you resolved it? I'm on Rsbp 3+. Thanks!
                  paradadf Staff @samba last edited by
                  @samba both emulator work if you add the bios files.
                  • samba
                    @paradadf Thanks so much for your help. Happy I'm not yet abandoned alone 😉
                    Actually, I have already tried everything I can. Of course I tried with blueMSX and fMSX with different versions.
                    One thing I found meanwhile, there is an error when I run a game in verbose mode via ssh:
                    [INFO] [MIDI]: Initializing ...
                    ALSA lib seq_hw.c:466:(snd_seq_hw_open) open /dev/snd/seq failed: No such file or directory
                    [ERROR] [MIDI]: snd_seq_open failed with error -2.
                    [ERROR] [MIDI]: Initialization failed (list of input devices unavailable).
                    Should this be a reason? This is a vanilla install with fMSX BIOS only. If you want me to try something different for logging, please let me know. Thanks!!
                      @samba a vanilla install is not enough. You MUST add the bios files.
                      • samba
                        @paradadf Thanks, but as I mentioned, I added fMSX files on top of vanilla Recalbox. Below is what I have in the bios directory. Do I need anything else? Please let me know!
                        -rw-r--r--    1 root   root     33152 Jan  4 15:00 CARTS.SHA
                        -rw-r--r--    1 root   root      2048 Jan  4 15:00 CYRILLIC.FNT
                        -rw-r--r--    1 root   root      2048 Apr 26 02:08 DEFAULT.FNT
                        -rw-r--r--    1 root   root     16384 Jan  4 15:00 DISK.ROM
                        drwxr-xr-x    2 root   root      4096 Apr 26 02:31 Databases
                        -rw-r--r--    1 root   root     65536 Jan  4 15:00 FMPAC.ROM
                        -rw-r--r--    1 root   root     16384 Jan  4 15:00 FMPAC16.ROM
                        -rw-r--r--    1 root   root      2048 Jan  4 15:00 ITALIC.FNT
                        -rw-r--r--    1 root   root    131072 Jan  4 15:00 KANJI.ROM
                        -rw-r--r--    1 root   root     32768 Jan  4 15:00 MSX.ROM
                        -rw-r--r--    1 root   root     32768 Jan  4 15:00 MSX2.ROM
                        -rw-r--r--    1 root   root     16384 Jan  4 15:00 MSX2EXT.ROM
                        -rw-r--r--    1 root   root     32768 Jan  4 15:00 MSX2P.ROM
                        -rw-r--r--    1 root   root     16384 Jan  4 15:00 MSX2PEXT.ROM
                        -rw-r--r--    1 root   root     65536 Jan  4 15:00 MSXDOS2.ROM
                        drwxr-xr-x  202 root   root     12288 Apr 26 02:32 Machines
                        -rw-r--r--    1 root   root   1009534 Jan  1  1980 NstDatabase.xml
                        -rw-r--r--    1 root   root     65536 Jan  4 15:00 PAINTER.ROM
                        -rw-r--r--    1 root   root     16640 Jan  4 15:00 RS232.ROM
                        drwxr-xr-x    3 root   root      4096 Jan  1  1980 amiga
                        -rw-r--r--    1 root   root    131072 Jan  1  1980 dc_nvmem.bin
                        drwxr-xr-x    3 root   root      4096 Jan  1  1980 fba
                        drwxr-xr-x    2 root   root      4096 Jan  1  1980 keropi
                        -rwxr-xr-x    1 root   root    524288 Jan  1  1980 kick02019.AROS.ext.rom
                        -rwxr-xr-x    1 root   root    524288 Jan  1  1980 kick02019.AROS.rom
                        -rw-r--r--    1 root   root      5218 Jan  1  1980 lisez-moi.txt
                        drwxr-xr-x    3 root   root      4096 Jan  1  1980 mame2000
                        drwxr-xr-x    3 root   root      4096 Jan  1  1980 mame2003
                        drwxr-xr-x    4 root   root      4096 Jan  1  1980 mame2003-plus
                        drwxr-xr-x    3 root   root      4096 Jan  1  1980 mame2010
                        drwxr-xr-x    2 root   root      4096 Jan  1  1980 np2kai
                        drwxr-xr-x    2 root   root      4096 Jan  1  1980 oricutron
                        -rw-r--r--    1 root   root      5104 Jan  1  1980 readme.txt
                        • samba
                          In my case, it turned out that only .zip worked. Neither .mx1 nor .rom ran, however, they all worked well after zipping them. I also tested on Retropie and Batocera, and confirmed they all had the same issue. Could be fMSX's issue. Hope this would help someone in the future.
                          101.4k
