    RecalBox does not work after the upgrade.
    recalbox does upgrade
    • tarzinio
      tarzinio last edited by
      I warmly welcome. I wanted to install recalbox for Ra Raspberry Pi 3+, but something does not work. The system was uploaded using the balenaEtcher program. I uploaded a micro sd card system (SanDisk Ultra 16GB a1 hc1). When you turn on Raspberry Pi, only the lightning icon appears on the screen.
      Hi,
      Ra Raspberry Pi 3+;
      SanDisk Ultra 16GB a1 hc1;
      I installed the beta system (February 2019 Beta Version).
      After updating from the panel, the system does not start.
      Does anyone know the reason?
      Greetings.
      Please forgive me for mistakes, but I do not speak English, so I translate it through google translate.
      • olivierdroid92
        Beta version shall not be upgraded
        • Bloodsurfer
          Bloodsurfer last edited by
          The lightning icon usually means that the power supply is not strong enough for the Raspberry.
          The first startup after the setup does take a bit longer than normal, because the OS is resizing the partitions on the SD card at first boot. This might take a minute or two depending on the card speed and size,so maybe you just need to wait a little bit longer.
          • flosch
            flosch last edited by
            I had the same issue after upgrading. I guess it would upgrade to the last stable version, which is not compatible with Raspberry PI3 B+.
            Right now, I think your best option is to re-flash the beta version on your SD card itself using etcher (and disable updates maybe once your reboot...)
            • olivierdroid92
              try again :
              https://forum.recalbox.com/topic/16576/february-2019-beta-version
              1st post
              quote
              F.A.Q
              There is a popup telling me there is an update! Wow you're fast!
              NO! NO! NO! No update at all until the final release! update = crash
              unquote
