    Solved Nintendo DS "Drastic" emulation in Recalbox
    Your discoveries
    nintendo recalbox
    3920
    • F0XHOUND
      F0XHOUND last edited by F0XHOUND
      Hi. This thing is a most common question. But i did it without a lot of difficult. By some reason Recalbox team doesnt like to add it? Is possible to write the steps to add Drastic in Recalbox?
        OyyoDams Staff @F0XHOUND last edited by
        @f0xhound already answered in this forum: drastic is closed source, so can't be added to Recalbox
        • F0XHOUND
          But is possible to get executable and add it to recalbox as reicast or ppsspp. Is a legality problem?
            @f0xhound we'll never add closed source software to Recalbox.
            • joinski
              joinski last edited by
              There are chances, that Drastic will become open-source later this year:
              "There's also been plans to make DraStic open-source, but not until it adds support for 64-bit[2] since Android is requiring all apps to support 64-bit by August 2019. More will be mentioned by spring of 2019 in terms of progress, but if things aren't going well, Exophase may "consider open sourcing so it can be tasked to others". "
              source: http://emulation.gametechwiki.com/index.php/DraStic
                paradadf Staff @joinski last edited by
                @joinski only when and if drastic becomes open-sourced, it will be considered for integration.
                • F0XHOUND
                  Thanks for all the info
                  101.0k
