    Shanwan PS3 controller input delay through bluetooth
    GamePad/GPIO/USB encoder
    shanwan ps3 input delay through
    • horotony
      horotony last edited by
      Hi guys,
      I know this is a common issue, but I still didn't manage to fix it in my recalbox.
      I have 4 shanwan dualshock 3 and, even though they are configured in the recalbox UI (they are not vibrating for no reason while connected), I still have an awful input delay in every emulator I use. This is probably related to the BT connection, since I don't have the same issue while connect via USB.
      What can I do to fix that? Would a bluetooth adapter connect to the RPpi3 usb slot help?
        paradadf Staff @horotony last edited by
        @horotony if you have a rpi3, yes, a bt adapter helps.
        horotony 1 Reply Last reply Reply Quote 0
        • horotony
          horotony @paradadf last edited by
          @paradadf is there any other solution?
