    eboot on PSX
    Emulator Arcade/PC/Console
    eboot
    4513
    • scrott901
      scrott901 last edited by
      Good evening all!
      I have just started with Recalbox on the XU4 and all my roms are working except for eboots on the PSX.
      Do these work on the PSX or will they run on PSP emulator?
      I have run these on Batocera with the PSX emulator (Batocera is a fork of Recalbox).
      Much love
        paradadf Staff @scrott901 last edited by
        @scrott901 PBP work on PSX, no problem on my end. Check for the right bios.
        scrott901 1 Reply Last reply Reply Quote 0
        • scrott901
          scrott901 @paradadf last edited by
          @paradadf thanks for info dude, where do the bios files go?
            @scrott901 we have very good video tutorials and wiki entry about a bunch of useful topics. Please take some time to take a look at them. Anyway, here it is:
            https://github.com/recalbox/recalbox-os/wiki/Add-system-bios-(EN)
            scrott901 1 Reply Last reply Reply Quote 1
            • scrott901
              @paradadf hi dude i have tried lots of different bios's and checked the md5 but all have failed to load a game 😞
              anyone able point in the right direction for the files....
              paradadf Zing 2 Replies Last reply Reply Quote 0
                @scrott901 google is your friend. Please read the forum rules. If you ask for copyrighted content, you‘ll be banned the next time.
                  Zing Global moderator Translator @scrott901 last edited by
                  @scrott901 said in eboot on PSX:
                  Have you installed the BIOS and checked md5 in Recalbox Manager?
                  If the BIOS is correct, and the MD5 is correct, your problem is not in the BIOS, have you tried changing the emulation core?
                  Have you tried with another ROM?
                  Which version of Recalbox are you using?
                  Have you even set up your Recalbox, or are you using a ready-made image from the internet?
                  Se a minha resposta foi Ăștil, por favor, dĂȘ um voto positivo, clicando na seta para cima logo abaixo da resposta, ao lado de "citar".
                  • scrott901
                    scrott901 @Zing last edited by
                    @zing How do you change emulation core as i only have PCSX Rearmed available.
                    I have tried nearly all my ROMs and running v18.07.13.
                      @scrott901 You did not answer the most important question and it is very difficult to help you ....
                      You have so far not made it clear that you are using the correct BIOS, which has verified that it is not just a matter of renaming to uppercase or lowercase, as in some cases.
                      You also did not answer:
                      • scrott901
                        didn't even know the manager existed but i found what the error was.
                        seems to be auto save/load would fail to launch rom.
                        many thanks for your help
