    RPi 3B + 7 inch LCD = issue with resolution on Kodi
    inch lcd issue kodi
    1776
    • Darijus
      Darijus last edited by
      Hi,
      Just installed a nice image of RecalBox on my RPi 3B with 7 inch LCD display. All the games work perfectly, resolution of RecalBox is good however once I try to switch Kodi it switches to a different resolution and the view is not centred ( screenshot: https://imgur.com/AbIUswZ ). Is there any way I can adjust Kodi resolution as on Kodi settings resolution settings are greyed out...
      Much appreciated,
      Darijus
        paradadf Staff @Darijus last edited by
        @darijus try adding
        kodi.videomode=default
        to your recalbox.conf.
        Darijus 1 Reply Last reply Reply Quote 0
        • Darijus
          Darijus @paradadf last edited by
          @paradadf It's already there. And also tried other modes, no difference.
            @darijus try using the same resolution as on global.videomode.
            • Darijus
              @paradadf Tried - no success. Still same.
                @darijus what type of screen are you using? How do you connect it to your pi?
