    WIFI key password with two simple quotes
    wifi key password simple quotes
    2548
    • kbz
      kbz last edited by
      Hi All,
      My wifi key is composed by two simple quotes ie: "IDon'tlikePeter'sBook".
      Despiste many tries I don't know how to setup it. I have tried with ' but id does not work.
      Do you have a recommendation ?
      Where & How
      • Where: in the conf file ? in the WebUI ? On the TV ?
      • How: How to baskslash this password ? ', '', ... ?
      Thank you for your help.
      K.
        paradadf Staff @kbz last edited by paradadf
        @kbz try with \'
        kbz 1 Reply Last reply Reply Quote 0
        • kbz
          kbz @paradadf last edited by
          @paradadf said in WIFI key password with two simple quotes:
          @kbz try with \'
          Hi paradadf,
          Thank you for your answer, I already tried, but without any success. Do I have to do it on the TV ? On the web interface ? On the config file ?
          Already tried all, don't work.
          Despite, if I change the key to my router with a simplier one, it work, so I really think the ' is not well saved within recalbox setup.
            @kbz
            in recalbox.conf https://github.com/recalbox/recalbox-os/wiki/recalbox.conf-(EN)
            ## Wifi SSID (string)
            ;wifi.ssid=new ssid
            ;wifi.key=\"totototototo\"
            • kbz
              kbz @acris last edited by
              Hello acris,
              thank you for your answer.
              I have tried --IDon\'tlikePeter\'sBook-- but it does not work.
              Any idea ?
              @acris said in WIFI key password with two simple quotes:
              @kbz
              ;wifi.ssid=new ssid
                @kbz said in WIFI key password with two simple quotes:
                do you delete ; before line ?
                • kbz
                  kbz last edited by
                  Yes of course.
                  I begin to be crazy!
