    Atari Jaguar Support
    Emulator Arcade/PC/Console
    atari jaguar
    • hex12
      hex12 last edited by
      Hi all,
      I read with very pleasure you will add Atari jaguar for X86.
      I would like to ask you if it will be available only on this system or also on XU4.
      In case of negative answer, the reason should be not enough power on XU4 or the absence of emulator?
      I should be grateful for any kind answer.
      Regards
      ProfMielPops paradadf 2 Replies Last reply Reply Quote 0
      • ProfMielPops
        ProfMielPops @hex12 last edited by
        @hex12 Hi,
        According to the wiki : https://github.com/recalbox/recalbox-os/wiki/Board-Compatibility-(EN)
        only on PC (x86) and PC (x86_64)
          paradadf Staff @hex12 last edited by
          @hex12 it was too slow for the xu4.
          hex12 1 Reply Last reply Reply Quote 0
          • hex12
            hex12 @paradadf last edited by
            @paradadf yes i read on the net that the libretro core for Odroid was really slow but there is the Virtual Jaguar stand alone that it was said works well on the XU4.
            I post this link where i took this notice, it was an article of 2016 on Odroid Magazine. I post it in the case you could take it as useful for the scope.
            https://books.google.it/books?id=JlwqDAAAQBAJ&pg=PA22&lpg=PA22&dq=jaguar+xu4&source=bl&ots=36PT0moJS3&sig=ACfU3U2FdhYog_25M32vhGhAxWHkmo3vAw&hl=it&sa=X&ved=2ahUKEwjU4cns65jgAhUFhqYKHTpuAnAQ6AEwCXoECAgQAQ#v=onepage&q=jaguar xu4&f=false
            Thanks for the answer.
              @hex12 adding a standalone emulator requires A LOT more work, so it is improbable that someone from the team will add it anytime soon, sorry.
