    Kodi is very slow and laggy when trying to watch 1080p x265 files (for example)
    MediaCenter & Dualboot
    kodi very slow laggy trying
    • Raspomain
      Raspomain last edited by
      Hi gents,
      I have got a raspberry pi 3b+. So far, I have no trouble for watching movies, animes, etc. Except when it comes to some particular formats like 1080p x265.
      Files are not particularly heavy : 300Mo, and it works pretty well on my computer with VLC. But in kodi, it is super laggy.
      I never changed recalbox or kodi initial configuration.
      At the begining, I thought it was due to the SD card, so I changed it to a very fast one ... without success.
      Did you already experiment this kind of issue ?
      Thank you in advance,
      Ra
        Zing Global moderator Translator @Raspomain last edited by
        @raspomain If you have Rpi3 + that indicates that you are using BETA, and all subjects about BETA, should be discussed in the BETA topic.
        • idarius
          idarius last edited by
          hi, it's not the SD card or your files, it's the Raspberry pi who can't handle the x265 format.
          Some files can be read but the experience is not smooth.
          If you want to read x265 files on a media center you need a better hardware, like some new android box, or a nvidia shield tv.
          • Raspomain
            Okay. I converted my files to x264 and it works properly ...
            Thanks for you answer.
            Zing: I was suspecting something no correlated with beta version.
            • DylanCooper
              DylanCooper last edited by
              Sometimes it happened, try again after few time probably it will work smoothly.
              101.4k
