    TR configured as hotkey
    configured hotkey
    2492
    • leviathan
      leviathan last edited by
      Hello. I've just built a new bartop with a recalbox Raspberry Pi 2+, connected every joystick and button as default mapped, tested and everything works just fine, except for 1 thing. TR1 is always set as HK1. If I press TR1+B menu pops up on, TR1+Select1 goes Back, and so on. I tried to remap via Menu setting any other button as HK but doesnt work, and real HK button does nothing. Anyone could please help with this? Thanks in advance.
      • digitaLumberjack
        Hi @Jose, did you tried to configure the controllers in the controllers settings menu ?
        • leviathan
          Hi there. Yep, and it didn't work. I remap every button until hotkey and mapping works fine. In hotkey I press the button connected to HK on GPIO and nothing happens. Checked wires and buttons and they are OK. Anyway if i press Select as HK doesn't work either, HK keeps bent to TR1. Don't know what else to do... Thanks.
          • leviathan
            No clues? I'm quite desperate...   Thanks!
              HUmmm it is weird, can you check your buttons with this wiki ? https://github.com/recalbox/recalbox-os/wiki/Test-your-joystick-with-jstest-(EN)
              • leviathan
                Hello again.   Did the test. Everything is fine on both GPIO controllers. Axis and buttons work fine and no shortcuts are present.   Still failing 😞
                • digitaLumberjack
                  Are you on 3.2.11 and are you triyng only to play mame games ?
                  • glooobule
                    glooobule last edited by
                    post your retroarchcustom.cfg with pastebin please.
