    How to convert changes made in recalbox to .IMG?
    Community projects
    convert changes made recalbox img
    • felipeadms
      felipeadms last edited by
      I learned how to change the intro, the themes among others in the recalbox through LAN with RJ45 cable. But how do I save these changes to an .IMG file? (to record to others SD cards)
        paradadf Staff @felipeadms last edited by
        @felipeadms it is not recommended to burn and image from another SD card into a different one, because there aren't two storage mediums with the exact same size. You'll end up not being able to burn the image, burning an incomplete image or losing some storage space.
        felipeadms 1 Reply Last reply Reply Quote 0
        • felipeadms
          felipeadms @paradadf last edited by
          @paradadf I understand, but even then I would like to know how to compile the changes made to a ".img" file image. Do you know how to do that?
          paradadf gnubit 2 Replies Last reply Reply Quote 0
            @felipeadms yes, you can use, for instance, Win32DiskImager.
            • gnubit
              gnubit @felipeadms last edited by
              @felipeadms said in How to convert changes made in recalbox to .IMG?:
              @felipeadms
              You could shrink your created image if your handy with linux by mounting the image as loopback, resizing it, then truncating it.
              https://softwarebakery.com/shrinking-images-on-linux
