    [Recalbox 9] Theme Next Pixel
    Themes & Interface
    theme recalbox 9
    148
    783
    1181072
    • mYSt
      mYSt Theme moderator @Patate last edited by
      @Patate Hi, make sure you didn't unzip theme in a fodler named next pixel (nextpixel/nextpixel/...)
      • toniosj
        toniosj Spanish moderator @Patate last edited by
        @Patate That is another problem. Check name folders.
        • siocone
          siocone last edited by
          I loaded with the 1080p theme
          the images were loaded with the scraper as described, but the preview video does not run in the monitor as described in the description. what am I doing wrong ?
          mYSt 1 Reply Last reply Reply Quote 0
          • mYSt
            mYSt Theme moderator @siocone last edited by
            @siocone said in [Recalbox 7.0+][Snap Videos][Custom mix] Next Pixel theme:
            Hello, you didn't read the documentation.
            Either you use next pixel mix, either you use "any mix" (seems its your case here) and in this case you have to adjust theme settings, check Next Pixel Mix documentation part for more info.
            • Stef11
              Stef11 last edited by
              Malgré le paramétrage en FR les infos (sur 4 lignes) des consoles reste en Anglais.
              Avez vous le même problème que moi ? Et avez vous une solution ?
              • mYSt
                mYSt Theme moderator @Stef11 last edited by
                @Stef11 Hello
                La version multilangue sera disponible pour la v2 du theme
                Stef11 1 Reply Last reply Reply Quote 1
                • Stef11
                  Stef11 @mYSt last edited by
                  @mYSt merci pour votre reponse
                  • skynet59
                    skynet59 last edited by
                    bonjour, est il possible que les videos se lance en lecture plus rapidement?
                    j'utilise une base PC, et il me faut 2-3s pour que la vidéo de présentation du jeux ce lance.
                    merci
                    Beho 1 Reply Last reply Reply Quote 0
                    • Beho
                      Beho @skynet59 last edited by
                      @skynet59 salut tu peux changer ça dans le recalbox.conf
                      PC Intel Q9650 4 go de ram Geforce GTX 670 2Go
                      Kit borne arcade de chez Fabrikaborne et déco maison
                      Kit 2 joueurs Joysticks + boutons lumineux EG Starts (Amazon) et 2 manettes Xbox One
                      Ecran 22p 16/9 full hd
                      Recalbox 7.1.1 x64
                      • skynet59
                        skynet59 @Bloodsurfer last edited by
                        @Bloodsurfer bonjour, merci de ton retour, sais tu quel ligne il faut édité?
                        est ce bien la? (le 2000)
                        ## Videosnaps
                        ### Delay before videosnaps start, in millisecond. Default: 2s
                        ;emulationstation.videosnaps.delay=2000
                        ### Video loop times. 0 = no video. 1 or more = the video loops x times before fading out
                        ;emulationstation.videosnaps.loop=1
                        ### Enable videosnap sound/music
                        ;emulationstation.videosnaps.sound=1
                        merci
                        • kevinnash
                          kevinnash last edited by
                          Oui @skynet59 c'est bien ce 2000 ms à modifier pour changer le délai de lancement de la vidéo.
                          skynet59 1 Reply Last reply Reply Quote 1
                          • skynet59
                            skynet59 @kevinnash last edited by
                            @kevinnash merci beaucoup
                            • Tamtam
                              Tamtam last edited by
                              Good evening and thank you for your theme! If you could make a theme with images that are "more 80s / 90s" that
                              would be great, like the old posters of Capcom arcade games for example (see photo)
                              In short, that is not why I am writing to you, but to ask you how to remove the logo that I point with an arrow on the photo that I sent you.
                              I put all my Capcom arcade games in the FBA directory, and the Pacman logo does a bit of a task.
                              cordially
                              c1f394bfbe12e9d9e3e94b2e7dc94f9b.jpg 10007101.jpg Capture d’écran 2021-01-24 193111.png
                              • mYSt
                                mYSt Theme moderator @Tamtam last edited by mYSt
                                @Tamtam Hello thanks for your feedback!
                                Next Pixel v2 will use only image from original box (and decal for arcade), so i guess this will match your request.
                                If you want to remove system logos for all systems you need to edit es-theme-next-pixel\data\systemviews\common.xml and remove all <image name="logo"> from line 42 to line 53 included.
                                If you want to remove for only one system open /[system]/data/custom.xml and add those lines to this file
                                <view name="system">
                                	<image name="logo">
                                		<path></path>
                                	</image>
                                	<image name="logo" region="eu">
                                		<path></path>
                                	</image>
                                	<image name="logo" region="us">
                                		<path></path>
                                	</image>
                                	<image name="logo" region="jp">
                                		<path></path>
                                	</image>
                                </view>
                                Tamtam 1 Reply Last reply Reply Quote 0
                                • Tamtam
                                  Tamtam @mYSt last edited by
                                  @mYSt Thanks for your reply, I am looking forward to having the new version. Good day to you.
                                  • Beho
                                    Beho last edited by
                                    Salut @mYSt juste par curiosité... elle en est où la mise à jour de ton thème ??
                                    Recalbox 7.1.1 x64
                                    • Manoot
                                      Manoot last edited by
                                      Bonjour à tous. Thème super beau et agréable.
                                      Je suis encore sur Recalbox 6, mais tout fonctionne parfaitement. J'ai malgré tout un souci. J'ai pour certaines consoles des sous-dossier type "jeux japonais". Le dossier s'affiche avec le nombre de jeu, aucun problème là dessus, par contre j'aimerais beaucoup afficher une image du dossier.
                                      J'ai ce code dans ma gamelist.xml
                                      <folder>
                                      <path>./# JAPON #</path>
                                      <name># JAPON (10 games)</name>
                                      <image>./downloaded_images/logos/japon.png</image>
                                      </folder>
                                      mais l'image prend tout l'écran et la qualité est déblorable...
                                      Comment je peux faire pour que cette image soit mise à la place de l'overlay avec l'image et la vidéo du jeu. Merci d'avance.
                                      mYSt 1 Reply Last reply Reply Quote 1
                                      • sheyk90
                                        sheyk90 @mYSt last edited by
                                        @mYSt said in [Recalbox 7.0+][Snap Videos][Custom mix] Next Pixel theme:
                                        TEASING NEXT PIXEL v2
                                        More game themes (160+), more retro, more emotional !!!
                                        next_pixel_v2
                                        When it will be available? Thanks for your job 😉
                                        • mYSt
                                          mYSt Theme moderator @Beho last edited by
                                          @Beho La nouvelle version dépend de fonctionnalités encore non dispo dans recalbox, je suis donc dans l'attente de celles-ci.
                                          • mYSt
                                            mYSt Theme moderator @Manoot last edited by
                                            @Manoot Hello merci pour ton retour, il faudrait que je test ça pour me rendre compte et pouvoir te répondre, malheureusement j'ai peu de dispo en ce moment
                                            Manoot 1 Reply Last reply Reply Quote 0
                                            100.8k
