    Recalbox Manager - Monitoring fails on 2010 Mac mini (including workaround)
    recalbox manager monitoring fails 2010
    • schorsch3000
      schorsch3000 last edited by
      Hi,
      i've installed Recalbox on an 2010 Macmini (Just dding the image onto the harddrive and creating the share-partition by my self).
      Everything works just fine (exept load heavy shaders, but thats what i get for such an old low performance hardware)
      except the monitoring in the Recalbox manager.
      Examin the problem results in
      get?option=temperature
      returns a 500, since in /usr/recalbox-manager2/dist/routes/get.js at line 189 there is:
      currentTemp = (0, _child_process.execSync)('cat /sys/class/thermal/thermal_zone0/temp').toString() / 1000;
      But there is no /sys/class/thermal/thermal_zone0, in fact with at least this kernel there is no thermal reading at all.
      I've fixed this for be my remounting / rw and changing sayed line to:
      currentTemp = (0, _child_process.execSync)('cat /sys/class/thermal/thermal_zone0/temp || echo -1').toString() / 1000;
      which results in a disabled Temperature reading, but all other readings work just fine.
      Im willing to fix this in the sourcecode and create a PR, but i did not found this pice of code in https://github.com/recalbox/recalbox-manager
      There seems to be a python implementation.
      So, is this a thing that should be fixed?
      Where is the code located?
      Thank so long!
        paradadf Staff @schorsch3000 last edited by
        @schorsch3000 that’s v1 (old) manager.
        Check this one out:
        https://github.com/DjLeChuck/recalbox-manager
        • peddletech
          peddletech Banned last edited by
          This post is deleted!
