    Displaying a pre-sorted gamelist.xml in Recalbox
    displaying pre-sorted gamelist.xml recalbox
    • nexusone13
      nexusone13 last edited by
      Hi all
      I have a pre-sorted gamelist.xml (multi criteria sorting generated with my little software ARRM ). Is there a way to make Recalbox display this Gamelist.xml as this, without applying his own sorting engine ? maybe it's a request for EmulationStation and not recalbox ? I have an option in ARRM to put an index in front of GameTitle to have games sorted but it's not very pretty.
      Thanks for your help 🙂
      ARRM (Another Gamelist, Roms manager, and Scraper for Recalbox, Batocera, Retropie) : http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager
      Wiki ARRM: http://www.jujuvincebros.fr/wiki/arrm/
      Discord: https://discord.gg/p7QsBTS
        voljega Banned @nexusone13 last edited by
        @nexusone13 afaik Recalbox displays by alphabetic order of the name tag or filename if no gamelist and there is no way to change it.
        And EmulationStation as a standalone project doesn't exist anymore, now each distribution has its own tweaked version of it
        nexusone13 1 Reply Last reply Reply Quote 0
        • nexusone13
          nexusone13 @voljega last edited by
          @voljega said in Displaying a pre-sorted gamelist.xml in Recalbox:
          😞 thanks for your quick reply
          • nexusone13
            Maybe it would be possible for recalbox (in the future) to handle a gamelist <sortname> tag (for example) ?
