    Can i disable Special commands?
    disable special commands
    4141
    • tlanks
      tlanks last edited by
      hi,   When i playing games,  i often press wrong buttons, that make me crazy~~~~~~~~ Can i disable Special commands? i don`t need them
      • digitaLumberjack
        Hi, are these special commands started without a key combination ? What is your hotkey ?
        • tlanks
          thx,it is not a hotkey problem. i jast wanna disable Special commands.     so ,plz which file should i edit ?
          • jose-antonio-castro-gonzalez
            jose-antonio-castro-gonzalez last edited by
            which is the special commands are?
            • tlanks
              HOTKEY+UP DOWN   B    L1 R2    and so on..............
              • idarius
                idarius last edited by
                hi, in the recalbox.conf file : ## Emulator special keys ## default -> default all special keys ## nomenu -> cannot popup the emulator menu ## none -> no special keys in emulators system.emulators.specialkey=default nomenu for disable the retroarch menu (hotkey B) none for disable all hotkeys (including save / reload etc...)
