    Roms not working with usb encoder/dragonrise but with the keyboard is okay?
    GamePad/GPIO/USB encoder
    dragonrise roms troubleshoot encoder keyboard
    2082
    • StandardShaun
      StandardShaun last edited by StandardShaun
      Hello,
      Any ideas why dragonrise joysticks on usb encoders should differ from a usb keyboard? When the keyboard is connected the roms work okay when I connect the joystick/buttons they config okay and work at the main menu but as soon as I load a game it fails to start (loads black screen for a few seconds then back to main menu).
      Any suggestions would be much appreciated!
        Zing Global moderator Translator @StandardShaun last edited by
        @standardshaun Hello!
        On which board are you running the system?
        Never worked or stopped working? If it stopped working, what did you do before it stopped working? If it never worked, what assures you that the usb encoder / dragonrise is working, ie what ensures that it is not the usb encoder that is in trouble?
        • kooper
          kooper Banned last edited by
          Hello, I think you have to check the USB encoder, I also had the same problem and it was the USB encoder.
          • Dragu
            Dragu Banned last edited by
            If it is a Raspberry, make sure that they are plugged into USB 0 (Player1) and USB 1(Player2).
            • kooper
              kooper Banned last edited by acris
              Have you did solve your problem? If so, I would like to know what the problem was.
              EDIT MODO
              PLEASE FORUM RULES NEXT TIME BANNED
              • Dragu
                @kooper
                Illegal stuff.
