    Twisted Metal 4 Multitap 4-players (PSX)
    Emulator Arcade/PC/Console
    twisted metal multitap 4-players
    • Jmf
      Jmf last edited by
      Is there any way to make the 4-players Twisted Metal 4 work?
      I already tried putting all the controls in "Standard" in the retroarch menu (which allowed me to play Crash Team Racing 4-players) but in this case it did not work.
      Nor did anything happen forcing the controls in emulationstation and I already tried enabling multitap 1, 2 and both at the same time.
      If multitap 1 is enabled you can not do anything because controller 1 does not work, so you can not even start the game
      If multitap 2 is enabled, controller 1 works, you can enter the menu, start a game of 4 but only let player 1 to select, when the moment of selection for player 2 comes nothing can be done, since controller 2 does not work
      Thank you very much and sorry for the basic English
      paradadf joinski 2 Replies Last reply Reply Quote 0
        paradadf Staff @Jmf last edited by
        @jmf may changing the pad type to „dualshock“ or „analog“? I suppose that game was release after the dualshock was introduced.
        Jmf 1 Reply Last reply Reply Quote 0
        • joinski
          joinski @Jmf last edited by joinski
          @jmf
          Which system do you use? Pi3 or a PC?
          I just installed Recalbox 18.07.13 on a new USB stick, then booted it up on my Intel NUC and connected 4 PS3 Controllers (original Sony DualShock3).
          At first i did a Controller remap and then i transfered all needed PSX BIOS Files and Twisted Metal 4 to the system and started the game.
          When in Game, i pressed Hotkey + B (X on PS3 Controller) and went to Quick Menu, Options and enabled Port 1 Multitap (i left Port 2 Multitap disabled). After resuming the game i exited it, by pressing Hotkey + Start.
          Then i started the Game again and 4 players works with no problems 🙂
          I just tried to do the same on my Pi3 with Recalbox 18.07.13, but unfortunately it does not work, because on Pi3 the default Emulator Core for PSX is PCSX_REARMED (= PCSX-ReARMed r22) and there is no other Core like MEDNAFEN_PSX (= Beetle PSX 0.9.44.1) available 😞
          MEDNAFEN_PSX is the default Core on X86_64 Recalbox and with this Core it works, but not with PCSX_REARMED.
          With PCSX_REARMED the problem is like you described above.
          • Jmf
            Jmf @paradadf last edited by
            @paradadf said in Twisted Metal 4 Multitap 4-players (PSX):
            Thanks for your answer
            I tried the controller type in analog but it did not work either
            The closest thing to work is activating multitap 2, deactivating 1, which activates the option for 4 players, but only control 1 responds
            Also tried with retropad, retropad w / analog but it's the same
            @joinski said in Twisted Metal 4 Multitap 4-players (PSX):
            @jmf
            Hi, thanks for your reply
            It's true, I forgot to mention that I use an RPI3
            So it must be a problem with pcsx rearmed and the game as you say
            I tried Twisted Metal 3 and it's the same, only controller 1 works
            • dada_savi
              dada_savi last edited by
              Hi, could you tell me what you did to play multiplayer on CTR?
