    The games won't load
    Emulator Arcade/PC/Console
    wont
    3970
    • eddrik
      eddrik last edited by eddrik
      Hello there,
      So today was another long day.
      Pi 3 b+, installed Recalbox once (beta build for pi3 b+) and installed the update without reading the thread about the beta version : I had to format and reinstall. :') That's not a big deal.
      But I could'nt launch a rom, even those that are built-in.
      And I cannot do so with my fresh install as well.
      I saw a few threads talking about corrupted SD Card, but could it be corrupted two times in a row ?
      I'm testing the recalbox with a VGA screen with HDMI converter.
      Any idea on what's going wrong here ?
      UPDATE : unsure if it's because of the beta build but Kodi media center have the same issue
      • joinski
        joinski last edited by
        Which controller are you using and did you remap your controller before starting the games?
        eddrik 1 Reply Last reply Reply Quote 1
        • eddrik
          eddrik @joinski last edited by
          @joinski I'm using a XBOX 360 wired controller and no, I did not. But it's working... fine ? I'll investigate asap, thanks for your reply, sorry for bothering.
          • Gaetan
            Gaetan Theme moderator @eddrik last edited by
            @eddrik you have to remap your controller, if not, you' ll always go back to ES.
            • eddrik
              eddrik @Gaetan last edited by
              @gaetan Sorry for the slow reply, it was the issue, I had to remap my controler as specified on the installation guide. I chosed to ignore this telling myself "why, this is working right now". Won't be as stubborn next time. Thank you and sorry for bothering you all.
              • Gaetan
                @eddrik No problem, have fun ! 😉
