    Recalbox problem on EEEPC 900A
    recalbox eeepc 900a
    • Shift74
      Shift74 last edited by
      I installed the RecalBox 18.07.13 on my eeepc 900a but I can not absolutely start any emulator.
      I arrive at the classic screen, I select the emulator and the game, I start and ... black screen.
      I think the problem is in the settings of the video mode in recalbox.conf (the EEEPC has a resolution of 1024x600) because there is no equivalent DMT configuration with that resolution, but I do not know how to solve it. Does anyone have any idea how to do it?
      Shift74 1 Reply Last reply Reply Quote 0
      • Shift74
        Shift74 @Shift74 last edited by
        Update: If I connect the EeePC 900A to the TV via VGA2HDMI I can see everything correctly on the TV (automatically set 1024x768) and on the screen of the EeePC (although in the latter, having a maximum resolution of 1024x600, are not shown 128pixel ).
          Zing Global moderator Translator @Shift74 last edited by
          @shift74 I can not guarantee, but maybe the command at this link will help you:
          https://forum.recalbox.com/topic/14398/menu-and-kodi-is-not-full-screen-on-old-netbook/4
          • Shift74
            Shift74 @Zing last edited by OyyoDams
            @zing Thanks for the reply. I solved by installing *** on my EeePC900A.
