    Solved New BIOS not show up in start menu
    Emulator Arcade/PC/Console
    bios show start
    1656
    • pablo_jf
      pablo_jf last edited by
      I'm a newbie on Recalbox.
      I tried to make a bootable USB and installed Recalbox on it with sucess.
      I added some BIOS, like Genesis and Atari, but didn't show up on start menu, and i can't figure out what i'm doing wrong.
      Thank's for any help.
      • Gaetan
        Gaetan Theme moderator @pablo_jf last edited by Gaetan
        @pablo_jf what do you mean by "start menu"? Did you add roms in the Genesis/Megadrive and Atari's folders ?
        • pablo_jf
          @gaetan i mean the Recalbox start screen, where you roll between consoles.
          No i didn't put any rom yet, just upload bios files.
          paradadf Gaetan 2 Replies Last reply Reply Quote 0
            paradadf Staff @pablo_jf last edited by
            @pablo_jf Bios files don´t show up, roms do.
            • Gaetan
              @pablo_jf so now, put your roms in your systems's folders and then they will appear in your start menu (aka carousel)
              pablo_jf 1 Reply Last reply Reply Quote 0
              • pablo_jf
                pablo_jf @Gaetan last edited by
                @gaetan thank you very much to ask a so noob question. I put some roms and it work. Thanks for the patiance.
                Regards.
