    How to update my Recalbox?
    Your recalbox
    update recalbox
    7935
    • nubirro
      nubirro last edited by nubirro
      Hi,
      I am using the version 17.12.2 in my Raspberry Pi3 and I want to upgrade it to the latest version (18.07.13) keeping my files. How can I do that? The update's message didn't appear yet.
      Thank you!
        paradadf Staff @nubirro last edited by
        @nubirro maybe the notification is turned off...
        Connect your Pi to the internet, press Start, navigate to System Settings and choose to update. I don´t have the exact menu names in mind, but it should be something like that.
        • Quemandoacromo
          Quemandoacromo last edited by
          @nubirro I always recommend doing a fresh installation. If you want to make a backup of your files you have to save the following folders:
          • /share/bios (bios and extra files)
          • /share/roms (games and favorites)
          • /share/system/.kodi (Kodi plugins and addons)
            Substring @Quemandoacromo last edited by
            @quemandoacromo you're missing some parts of what should be saved ...
            Quemandoacromo 1 Reply Last reply Reply Quote 0
            • Quemandoacromo
              Quemandoacromo @Substring last edited by
              @substring Sorry, I usually copy those folders and then I just have to configure the controls and emulators 😞
              What are the recommended folders to save?
              (I have not seen anything about it on the wiki)
              paradadf Substring 2 Replies Last reply Reply Quote 0
                paradadf Staff @Quemandoacromo last edited by
                @quemandoacromo your saves folder, for example.
                  @quemandoacromo everything on the share folder ! You had forgotten the save folder or even the whole system folder
