    Dreamcast Screen is small
    dreamcast small
    4968
    • Patrick Lynch
      Patrick Lynch last edited by
      Every other rom goes full screen or close to it except Dreamcast roms. Any idea how to resize??
        Substring @Patrick Lynch last edited by
        @patrick-lynch first of all hello
        And, still regarding basics that are lacking, how can i guess your setup ...
        Patrick Lynch 1 Reply Last reply Reply Quote 0
        • Patrick Lynch
          Patrick Lynch @Substring last edited by
          @substring Im sorry getting frustrated. What info do you need? Its running on a Rasp 3 using an xarcade controller. Using the latest version of recalbox.
            @patrick-lynch what screen do you have ?
            • Patrick Lynch
              @substring 65" Sony Bravia
                @patrick-lynch as i thought : you're playing On a tv. The tv should upscale and not display 1:1, so check in the settings
                • Patrick Lynch
                  @substring on the TV? Why would it upscale all other emulators except that one? Btw thank you very much for the help
                    @patrick-lynch i bet you haven't tried N64 as you would face the same.problem
                    For performance purpose, N64 and Dreamcast run in 640x480, whereas all other emulators run in 720p (1280x720)
                    joinski 1 Reply Last reply Reply Quote 0
                    • joinski
                      joinski @Substring last edited by joinski
                      @substring said in Dreamcast Screen is small:
                      But this only affects RPi2/3, right? Because I use Recalbox x64 PC version and there the resolution of Dreamcast and N64 is definitely greater than 640x480.
                        Substring @joinski last edited by
                        @joinski pi only indeed, there is no resolution switch on anything else than pi
                        • joinski
                          @substring
                          Thanks!
                          Is there a way to reduce the resolution for Dreamcast to 640x480?
                            @joinski on which board ?
                            joinski Patrick Lynch 2 Replies Last reply Reply Quote 0
                            • joinski
                              @substring
                              you mean which system? PC x64
                                @joinski there is no resolution switching (yet ?) On x86
                                • Patrick Lynch
                                  @substring So im basically stuck im using pi 3...that sucks...
                                    @patrick-lynch it's a tv problem buddy, it should upscale 640x480 to fullscreen. This is not a recalbox problem
