    Dreamcast pulling my hair out.
    Emulator Arcade/PC/Console
    dreamcast pulling hair out
    7
    12
    5633
    • coldmantis
      coldmantis last edited by
      Hi Everyone, I'm new here and I'm struggling to get Dreamcast to load games, I put in the correct bios that matchs the checksum in the bios folder, I even tried the region free one (also matches checksum) when I try to load any game it loads into black screen and then goes back into the game list. Same with neogeo but I can't seem to find the correct checksum bios for that one.
      • abunille
        abunille @coldmantis last edited by abunille
        @coldmantis
        Hi,
        please give us more details about your game files for Dreamcast.
        Which Hardware?
        have you "first" use the search function in the Forum?
        EDIT:
        For neogeo:
        I hope you know that the neogeo.zip BIOS must be placed in the neogeo rom folder and NOT in the bios folder.
        • coldmantis
          coldmantis last edited by coldmantis
          @abunille thanks for the response, yes I have use search/google/reddit/discord. I still have this issue, the games files are "name of game", space, "(region)" then it ends with .cdi.
          As for neogeo bios I must of tried at least 6-8 of them, I put them in the neogeo folder which didn't work, then I also copied them into mame, FB and bios folders. It does the same just loads to black screen and back to game list. Due note that I cannot find the Correct Checksum number that matches the wiki for the neogeo bios, the DC however matches both the bios regular and region free.
          Opps forgot my hardware I don't recall the hardware since I'm not home I believe it's a Lenovo T440 i7 for sure 8gb of ram, and maybe intel HD 4400 graphics. Recalbox and roms are located on 2.5" 500GB Hardrive connected with a sata to usb adapter (active not passive).
            paradadf Staff @coldmantis last edited by
            @coldmantis you need the correct bios depending on the required romset version, so don‘t worry about the md5 checksum shown on the wiki for arcade systems.
            coldmantis 1 Reply Last reply Reply Quote 0
            • coldmantis
              coldmantis @paradadf last edited by
              @paradadf
              ok that makes sense we are talking about neogeo right? not about dreamcast roms. It's been a long time since I play emulators, I recall there was like a program where you can load your rom directory and it checks a dat file or something, It's been so long that I don't recall the name of the program or where to start? any advise?
                @coldmantis read the wiki, look for the word „arcade“
                • Quemandoacromo
                  Quemandoacromo last edited by Quemandoacromo
                  Check hashes (BIOS region free):
                  • dc_boot.bin > d552d8b577faa079e580659cd3517f86
                  • dc_flash.bin > 74e3f69c2bb92bc1fc5d9a53dcf6ffe2
                  Put those 2 files in the BIOS folder (/share/bios),move your games files (*.cdi or *.gdi) to the Dreamcast folder (/share/roms/dreamcast) and everything should work without problems
                  Proof:
                  Power Stone with glitchs
                  (Power Stone.gdi + extra files)
                  MvsC2 with glitchs
                  (Marvel vs. Capcom 2.cdi)
                  @coldmantis
                  jorgemagana 1 Reply Last reply Reply Quote 0
                  • jorgemagana
                    jorgemagana @Quemandoacromo last edited by
                    @quemandoacromo said in Dreamcast pulling my hair out.:
                    Proof:
                    MvsC2 with glitchs
                    @coldmantis
                    Proof:
                    MvsC2 with glitchs
                    @coldmantis
                    Can you listen the music in main menu in mvsc2?
                    Quemandoacromo 1 Reply Last reply Reply Quote 0
                    • Quemandoacromo
                      Quemandoacromo @jorgemagana last edited by
                      @jorgemagana Yes,I can listen to the music in the screen of selection mode
                      • jorgemagana
                        @quemandoacromo thanks, I can not, I do not know what I am doing wrong.
                        • Jaladhjin
                          Jaladhjin last edited by paradadf
                          Do not ask for copyrighted content!!!
                          I have found some downloads but they are not working with Recalbox 😞
                          Probably because they are not the exact MD5s
                          • AndrewBoy_hun
                            AndrewBoy_hun last edited by
                            This post is deleted!
                            100.8k
