    Cant boot recalbox
    cant boot recalbox
    9596
    • guiddqd
      guiddqd last edited by
      Hello, I get this message when trying to boot recalbox on a sd card with my nuc8i7hvk from Intel.
      Mounting LABEL=RECALBOX on /new_root failed : no such file or directory.
      Anyone got it working on a nuc like mine?
      Thanks for your answers.
        Substring @guiddqd last edited by
        @guiddqd can you try booting in legacy bios and not uefi ?
        guiddqd 1 Reply Last reply Reply Quote 0
        • guiddqd
          guiddqd @Substring last edited by
          @substring no because my tv doesnt display the bios for some reason.
          I had to disable secure boot elsewhere but now Im stuck with this one again.
          Substring abunille 2 Replies Last reply Reply Quote 0
            @guiddqd from what i guess, the initramfs can't find the recalbox root partition (it"s supposed to be found using the partition label), and this mostly happens when booting in UEFI. Maybe @abunille has some advice regarding NUCs
            • abunille
              abunille @guiddqd last edited by
              @guiddqd
              The NUC shows the "F2" option on Startup? (If not, bios has enabled fast boot)
              If you can, try with another TV. (maybe resolution problem)
              Try another graphic port (Mini-DP)
              Look for the latest BIOS and update your BIOS.
              https://www.intel.com/content/www/us/en/support/articles/000005847/mini-pcs.html
              • guiddqd
                guiddqd last edited by guiddqd
                @abunille Thanks for your answers guys.
                I can see the F2 option, fast boot isnt enabled.
                It seems its a nuc related issue, sd cards cant boot on it. Not 100% sure about that though.
                I flashed an usb stick instead and...surprise another error:
                Giving up
                Cannot connect to x server or something.
                Pretty frustrating 😞
                • abunille
                  @guiddqd
                  Dont give up 🙂
                  My answers above were only for your BIOS problem.
                  On an old test nuc5 the problem was solved after bios update.
                  Another test NUC BIOS showed up after plug on DP Port and not in HDMI.
                  guiddqd 2 Replies Last reply Reply Quote 0
                  • guiddqd
                    guiddqd @abunille last edited by guiddqd
                    @abunille no I meant the error message was 'giving up etc.' 😛
                    Thats when I boot recalbox verbose, should have pointed that out sorry!
                    I gave up with the sd card but the usb looks like it will work if I get around that error!
                    • guiddqd
                      @abunille
                      @Substring
                      Maybe this picture can help identify the problem?
                        @guiddqd it says segmentation fault 😕 now that's annoying
                        gnubit 1 Reply Last reply Reply Quote 0
                        • gnubit
                          gnubit @Substring last edited by
                          @substring @guiddqd
                          looks like Radeon™ RX Vega M GH graphics on your NUC is only supported on kernel 4.15+ 😞 Beast of a box though...
                          guiddqd Substring 2 Replies Last reply Reply Quote 0
                          • guiddqd
                            guiddqd @gnubit last edited by guiddqd
                            @gnubit
                            @Substring
                            Oh...Im sorry but what does that mean?:(
                            Anything I can do?
                            • gnubit
                              gnubit @guiddqd last edited by
                              @guiddqd
                              That`s OK mate. Basically what it means that is that your new hardware namely the GPU (graphics card) is not currently supported as the kernel in Recalbox is version 4.8 (the kernel is the lowest level of software that interfaces with the hardware in your computer). I hear that Recalbox is getting a kernel/OS upgrade soon that will hopefully support your hardware. @Substring may be able to shed some light on this.
                                Substring @gnubit last edited by
                                @gnubit well, we're on 4.15 on the next major system upgrade, so it should work. The beta should open during august
                                • guiddqd
                                  @gnubit
                                  @Substring
                                  Thanks a lot for your help guys. I guess Ill wait or try batocera in the meantime! Id rather use recalbox though.
                                  • guiddqd
                                    Hello, I tried again today with the new version. Still the same error...
                                    • guiddqd
                                      Nobody?
                                      It feels amazing to buy a sophisticated machine like this and not being able to do simple things like gaming on it...
                                        Zing Global moderator Translator @guiddqd last edited by
                                        @guiddqd Hello!
                                        When you say you tried with the new version, did you try with the open beta version? If so, you should post your issues on the open beta topic, only then developers can help. It's impossible for developers to see and respond to all threads, so it takes patience and understanding, but if you really want them to solve your problem, it's much better if you take part in the tests and give your feedback, after all it's not just your problem that needs to be solved, and it's not everyone who has the same problem as yours.
                                        • guiddqd
                                          I cant find the beta version. I'll try that and give feedback as soon as I can.
