    Can't connect to Recalbox
    cant connect recalbox
    10045
      Substring @oluminion last edited by
      @oluminion run ps -ef | grep node | grep "dist/server.js"
      oluminion 1 Reply Last reply Reply Quote 0
      • oluminion
        oluminion @Substring last edited by
        @substring said in Can't connect to Recalbox:
        No output so i guess it is not running. But the recalbox.conf is still in standard config:
        Recalbox Manager (http manager)
        system.manager.enabled=1
        1 or 2, depending on the manager version you wish
        system.manager.version=2
        So what can the cause be?
        Thank you very much for your patience.
        • tonificante
          tonificante last edited by
          I had yesterday a similar problem after 18.07.13 update, but my problem was only with the ssh connection. After rebooting several times and checking everything, the only thing that actually helped was to shutdown the router and turn it on again (in my case, I waited 10 seconds). Only after that, ssh was working.
            @oluminion set the manaver to version 2, make sure it's started in the advanced settings in es
            100.6k
