    Can't connect to Recalbox
    cant connect recalbox
    11229
    • oluminion
      oluminion last edited by
      Hi all,
      as the title says, i am not able to connect to Recalbox. Neither via putty, explorer nor webinterface.
      When i look under network config in emustation, it has got an ip adress from my dhcp server. So do the two pcs from which i want to connect to Recalbox. One i connected via wifi the other via cable to the Router where also Recalbox is connected.
      I am running Recalbox 4.1 and Windows 7 on the PCs.
      Everything worked fine in the same configuration under Recalbox 4.0 but after installing 4.1 onto the SD card, Recalbox runs fine except that i can't connect from anywhere.
      Can someone help me please?
      Thank you very much.
      Greetings Adrian
        Substring @oluminion last edited by
        @oluminion Hi
        Can you ping at least recalbox using the address given in the network settings ?
        oluminion 1 Reply Last reply Reply Quote 0
        • oluminion
          Sorry forgot to mention that, no ping also does not work. No connection on either way. Normally i would assume, the Recalbox does not have an IP, but atleast under network it has one.
          • oluminion
            oluminion @Substring last edited by
            @substring
            • MilesCW
              MilesCW last edited by
              It's a current bug I also have. In my case I have to disable Wifi and enable it again so it starts working.
              • oluminion
                oluminion @MilesCW last edited by
                @milescw
                Thank you for the answer, will test it when i am at home. Is your Recalbox connected via cable or wifi? Mine is connected to the Router by cable.
                MilesCW Substring 2 Replies Last reply Reply Quote 0
                • MilesCW
                  MilesCW @oluminion last edited by
                  @oluminion said in Can't connect to Recalbox:
                  Router by cable.
                  By wifi.
                    @oluminion does your router see it at least ?
                    • oluminion
                      @substring
                      Yes, when i log into my Router i can See recalbox. Also with the ip that is shown in emustation, so there is some Kind of connection, but other devices have trouble connecting.
                        OyyoDams Staff @oluminion last edited by
                        @oluminion are you using PI3 internal wifi ?
                        oluminion 2 Replies Last reply Reply Quote 0
                        • oluminion
                          oluminion @OyyoDams last edited by
                          @oyyodams
                          No the RPi3 is connected via cable over dLAN with the router.
                          • oluminion
                            @oyyodams
                            @Substring
                            Ok after several reinstalls and tests, things changed a bit but not yet good.
                            I can connect via wifi, though the mentioned bug forces me to turn wifi off and on after every reboot. With wifi working i can access via ssh and samba, so i got my games on the pi by now, but i can't get a connection to the webinterface.
                            Also to me the systems seems very slow, sometimes i wait for a minute after clicking on network for example.
                            Hope you may have some suggetions for these effects.
                            Thank you.
                              @oluminion should be fixed with today release (i hope). Download straight rhe img at archive.recalbox.com
                              • oluminion
                                @Substring
                                Thank you for the info. Seems to be working fine for the wifi part, so now everything is fine except that i can't connect to the webinterface. It is enabled in the conf, but neither by ip nor by http://recalbox i get an connection.
                                Any idea on how to fix the last problem?
                                  @oluminion try with your recalbox IP
                                  • oluminion
                                    @substring
                                    Neither connection method works ip nor http://recalbox
                                      @oluminion i guess there is something wrong in your router or network setup ... You could eventually locally log on recalbox with a keyboard (F4 to exit ES, CTRL+ALT+F2 to reach a terminal) and try to ping all those other network devices.
                                      • oluminion
                                        @substring
                                        I ssh'd into recalbox and pinged the router aswell as the pc i am trying to reach the webinterface from and both pings worked without any packet loss
                                          @oluminion is the manager started at least ???
                                          • oluminion
                                            @substring
                                            How do i check that?
