    Solved MSX system does not work after upgrade to version 18.06.27
    Emulator Arcade/PC/Console
    msx does upgrade version 18.06.27
    9
    26
    13197
    • leaf
      leaf last edited by
      Hello everyone! Sorry for my English. I have a problem with my recalbox. After updating the recalbox to version 18.06.27, the MSX system games no longer work. I already tried to change the bios but it did not work. Is anyone also having trouble running MSX system games after upgrading? Colecovision games, with bluemsx core is running normal. Thanks in advance!
      aciddreamer 1 Reply Last reply Reply Quote 1
      • aciddreamer
        aciddreamer @leaf last edited by aciddreamer
        @leaf true i just try it and none of them is working, sooo i think it will be fix on the next upgrade...
        also u cant put coins on capcoms mame games, soo that also will be fixed (as the moderator said to me)
        leaf 1 Reply Last reply Reply Quote 1
        • leaf
          leaf @aciddreamer last edited by
          @aciddreamer Thanks for the reply! I'll wait for the next update. I thought the problem was only with me. thank you so much! : D
          paradadf 1 Reply Last reply Reply Quote 1
            paradadf Staff @leaf last edited by
            @leaf I‘m not sure the problem with bluemsx will be solved before the next release, as the core compiles just fine but the games don‘t start. You can change the core to fmsx in the meantime... mind the bios.
            • leaf
              leaf @paradadf last edited by
              @paradadf I tried to change the core to fmsx, but it is not available. the only one available to use is bluemsx. Thanks for the reply.
                @leaf it is available. There are two parameters that need to be changed and none must show (default).
                • Quemandoacromo
                  Quemandoacromo last edited by Quemandoacromo
                  BlueMSX dont work,select FMSX and they work without problems.
                  You need these files in the BIOS folder (/share/BIOS):
                  d6dedca1112ddfda94cc9b2e426b818b CARTS.SHA
                  85b38e4128bbc300e675f55b278683a8 CYRILLIC.FNT
                  80dcd1ad1a4cf65d64b7ba10504e8190 DISK.ROM
                  af8537262df8df267072f359399a7635 FMPAC16.ROM
                  6f69cc8b5ed761b03afd78000dfb0e19 FMPAC.ROM
                  c83e50e9f33b8dd893c414691822740d ITALIC.FNT
                  febe8782b466d7c3b16de6d104826b34 KANJI.ROM
                  2183c2aff17cf4297bdb496de78c2e8a MSX2EXT.ROM
                  7c8243c71d8f143b2531f01afa6a05dc MSX2PEXT.ROM
                  6d8c0ca64e726c82a4b726e9b01cdf1e MSX2P.ROM
                  ec3a01c91f24fbddcbcab0ad301bc9ef MSX2.ROM
                  6418d091cd6907bbcf940324339e43bb MSXDOS2.ROM
                  aa95aea2563cd5ec0a0919b44cc17d47 MSX.ROM
                  403cdea1cbd2bb24fae506941f8f655e PAINTER.ROM
                  279efd1eae0d358eecd4edc7d9adedf3 RS232.ROM
                  @paradadf Creo que el problema esta en las carpetas que usa por defecto el emulador BlueMSX
                  (comentaron algo sobre el tema en los foros de Retropie,tengo que buscar el hilo)
                  • leaf
                    @paradadf I checked here, I changed the two parameters, but Fmsx is not available. Could you look and confirm if Fmsx appears to you? In msx here only the Bluemsx core appears. thanks in advance!
                      @leaf change the emulator to „libretro“ and the core to „fmsx“. It works, I have tested it.
                      leaf Gaetan 2 Replies Last reply Reply Quote 0
                        paradadf Staff @Quemandoacromo last edited by
                        @quemandoacromo si encontras la solucion te agradeceria que la compartas, preferiblemente en un issue en gitlab.
                        • leaf
                          @paradadf Thank you so much for checking! Unfortunately for me does not appear, even following what you said. I'll show you pictures of how it appears to me.
                          alt text
                          alt text
                          ]alt text
                          • Gaetan
                            Gaetan Theme moderator @paradadf last edited by
                            @paradadf is the core fmsx available on pi3 ?
                            I can't change it neither.
                            leaf 1 Reply Last reply Reply Quote 0
                            • leaf
                              leaf @Gaetan last edited by
                              @gaetan Mine is the pi3 too.
                              • Quemandoacromo
                                No problems here (Raspberry Pi 3 + Recalbox 18.06.27):
                                Advance Menu
                                Core
                                MGS (MSX2) running smoothly with FMSX 🙂
                                alt text
                                  @leaf are you using an official recalbox image?
                                  Gaetan leaf 2 Replies Last reply Reply Quote 0
                                  • Gaetan
                                    Gaetan Theme moderator @paradadf last edited by Gaetan
                                    @paradadf Yes, sorry to bother, it 's ok with fmsx 🙂
                                    • leaf
                                      leaf @paradadf last edited by leaf
                                      @paradadf I downloaded it from another site in which it compiled the official image of Recalbox version 18.03.30. I downloaded it because I already had all the games included in several systems. But I already did two updates online for the own recalbox, so I think that even if the image was not official, after updating online it would be official.
                                        @paradadf dude can you please open an issue on gitlab and assign it to me please ?
                                          @leaf well, it obiously is showing problems which our official release doesn‘t have. Backup your roms, bios and save files and do a clean installation. Otherwise I can‘t help you further, sorry.
                                            paradadf Staff @rockaddicted last edited by
                                            @rockaddicted of course.
