    RB version 18.04.20 does not update to 18.06.27 - Download Error by Lan
    version 18.04.20 does update 18.06.27
    4615
    • NESTALGIC
      NESTALGIC last edited by
      I tried to update RB OS using "update"menu, but it shows an error message.
      Steps:
      • start update
      • in progress
      • update the system? y/n
      • in progress
      • downloaded: 0/ 249MB (0%)
        After 10 minutes: "An error ocurred - downloaded: 0/ 249MB (0%)"
      == RPi3
      == v. 18.04.20
      == wired connection
      Thx!
        OyyoDams Staff @NESTALGIC last edited by
        @nestalgic hi,
        please check your network connection, and if you have enough space on your sd card.
        • NESTALGIC
          Hi @OyyoDams,
          Internet/ network connection are ok.
          I have a 64GB SD card and it has 90% space free.
          Thx!
            @nestalgic are you ok if I ask you to connect to Recalbox through ssh ?
            • NESTALGIC
              Hi @OyyoDams. Ok. But how can we do that?
                @nestalgic please read this page: https://github.com/recalbox/recalbox-os/wiki/Root-access-on-terminal-(EN)
                Then once connected to Recalbox, enter this command:
                bash -x /recalbox/scripts/upgrade/recalbox-upgrade.sh upgrade
                Can you give me the result ?
                • NESTALGIC
                  I've tried two different ways according that URL you sent me: 1) using the internal terminal; 2) by pressing F4 to quit, then ALT+F2 to get a terminal (keyboard).
                  The same error (attachment).
                  Screenshot
                  OyyoDams NESTALGIC 2 Replies Last reply Reply Quote 0
                    @nestalgic which attachment ?
                    • NESTALGIC
                      NESTALGIC @NESTALGIC last edited by
                      SCREENSHOT
                        @nestalgic the upgrade server is currently down, please try again later
                          It's now up again
