    Bug 18.06.27
    bug
    10
    14
    4698
    • DJC
      DJC last edited by
      I’ve found a bug when I use select and hot key on the same button, some games don’t insert coin, only on coin 2.
      Happened in MAME and FBA, someone can confirm?
      Games that happened:
      MAME - Side Arms
      FBA - Pac Man 25th Anniversary Edition.
      So far his are the games that I discovered this bug, tested with an USB controller and it works fine w/o problem.
      Maybe there are another games but for now I found these two.
      PS: one more game, SF3 FBA, can’t coin on both coins.
      DJC 1 Reply Last reply Reply Quote 0
      • DJC
        DJC @DJC last edited by
        @djc said in Bug 18.06.27:
        MAME - Side Arms
        More games to add to the list, a lot more, all CPS2 games can’t coin on choin 1.
        Got into input test to see and the coin pulse seems to be so fast that the game can’t coin.
        CapFuture1975 1 Reply Last reply Reply Quote 0
        • getflashed
          getflashed last edited by
          Controller-Setup crashes and hangs up to black Screen (with version and small logo)
          after stable update the controller-setup dialogue crashes after skipping some buttons reproducible with USB-Controller and 8bitdo NES30 Pro
          System RPi 3 B
          regards
          Getflashed
            Substring @getflashed last edited by
            @getflashed hi
            Thanks for reporting a bug. Can you give me a precise step-by-step to reproduce it ? Thank you
            getflashed thetrauck 2 Replies Last reply Reply Quote 0
            • getflashed
              getflashed @Substring last edited by
              @substring crash happened while skipping 3-4 buttons (usb controller without joystick), on 8bitdo NES30 Pro did a false button and wanted to skip to cancel also crash after 3-4 times down. i just tried it twice again and everything works fine, so perhabs not so reproducible as i thought.
              • thetrauck
                thetrauck @Substring last edited by
                @substring The same thing happened to me in mame games, I can not enter coins, in games like:
                Captain Commando
                knight of the round
                dungeons & dragons: tower of doom
                The King of Dragons
                etc.
                system RPi 3 B
                Saludos
                thetrauck
                • cowseye
                  cowseye last edited by
                  Not sure if mine is a new bug. Since I updated, I cannot get any sound. Not even theme music at menu selection. In settings, I saw my sound was set to 0%. The sound didn't come back even after I set it to 100%. Tried all sound output methods but none work.
                  I am running recalbox on a PC using onboard sound output jack. Not through hdmi.
                  joinski 1 Reply Last reply Reply Quote 0
                  • joinski
                    joinski @cowseye last edited by
                    @cowseye
                    Open kodi and then go to sound settings and try different outputs there until you find the right one.
                    Then exit kodi and you should have sound again in ES menu and games 😉
                    • CapFuture1975
                      CapFuture1975 @DJC last edited by
                      MAME - Side Arms
                      Same here! I can´t "insert" coins in mame.
                      • gnubit
                        gnubit last edited by
                        @cowseye
                        you could try from the terminal/ssh to list your sound cards:
                        aplay -l
                        Then assign the correct card accordingly (either from ES or Kodi as @joinski has suggested)
                        Archlinux wiki is has great info on troubleshooting alsa: https://wiki.archlinux.org/index.php/Advanced_Linux_Sound_Architecture#Unmute_with_amixer
                        Here is my example from my box: (aplay -l)
                        **** List of PLAYBACK Hardware Devices ****
                        card 0: PCH [HDA Intel PCH], device 0: ALC283 Analog [ALC283 Analog]
                          Subdevices: 1/1
                          Subdevice #0: subdevice #0
                        card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
                          Subdevices: 0/1
                        card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
                          Subdevices: 1/1
                        card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
                          Subdevices: 1/1
                        • CapFuture1975
                          CapFuture1975 @CapFuture1975 last edited by
                          @capfuture1975 said in Bug 18.06.27:
                          MAME - Side Arms
                          The "Hotkey"-Button must be not equel to the "Coin"-Button then it works! After I have changed the Hotkey-Button to something else then SELECT (Now it ist the left button (home) on the small side of the FC30 Pro Pad)
                          • messa
                            messa last edited by
                            I find the same issue today, if select is defined like hotkey in some mame games don't insert coins... In all the older version it worked perfectly... I come back to previous version because in my cabinet I have no more buttons to setup. Let's wait for another update with a solution.
                            • barbudreadmon
                              barbudreadmon @messa last edited by
                              @messa Nothing changed in the input code of fba/mame for this release, so it is either a recalbox issue, or a regression in retroarch (this issue existed ~2 years ago) where the input system was refactored between 1.6.9 and 1.7.3
                              Libretro developper :
                              • FBAlpha FBNeo (Arcade)
                              • Kronos (Sega Saturn/ST-V)
                              • YabaSanshiro (Sega Saturn)
                                Substring @barbudreadmon last edited by
                                @barbudreadmon there is a.patch to turn select into hotkey after 10 frames if both are equal, so this could be the faulty one as afterall, it doesn't seem related to fba only
