    Freeplay CM3 GBA clone Kit.
    Your discoveries
    freeplay cm3 clone kit
    39697
    • Dragu
      Dragu Banned last edited by
      @Substring
      I think that the actual installed mk_arcade_joystick_rpi.ko that works on PI3 should also work on CM3. Problem, the GPIO is different, so I ask myself where to configurate this. I have in etc/modprobe.de a file mk_arcade_joystick.conf, described also with the kernel object. And inside
      options mk_arcade_joystick_rpi map=4 gpio=4,17,6,5,19,26,16,24,23,18,15,14,-20,-1,-1,-1,-1 hkmode=2
      Problem also, map=4 seams strange to me. I think @LumberJack could help here, because he is the keeper of mk_arcade_joystick_rpi.ko.
        Substring @Dragu last edited by
        @dragu the most probable reason is that the ko included in freeplaytch/retropie is not the hotkey branch that we are using, but the master branch, which has different options. I should sooner upgrade the hotkey branch that will have the same features as the master branch (tested by @ian57 and myself). I may compile one for you if you wish
        • Dragu
          @Substring
          I compared an older Freeplaytech image from 21.03.18 and the .ko is exactly the same as we use in Recalbox, I made Hex compare and length also 11864, so it should work with basic gpio buttons. In this case, in /etc/modprobe.d/mk_arcade_joystick.conf you have this
          Later on he recompiled mk_arcade_joystick_rpi.c with own modifications. But this could just be a second step. Normal buttons should work as they work for PI3 also. now GPIO is different, where he knows this and than you have in the description from mk_arcade_joystick_rpi :
          Then create the file /etc/modprobe.d/mk_arcade_joystick.conf :
          sudo nano /etc/modprobe.d/mk_arcade_joystick.conf
          and add the module configuration :
          options mk_arcade_joystick_rpi map=1,2
          With my basic knowledge of Linux, I am hanging, but I believe that it is before all a configuration problem.
          • Dragu
            @Substring
            And exactly when I was writing, I have some reactions on the GBA buttons ! Some wrong but it begins to work, yeah ! The apple is near.
            • Dragu
              @Substring
              @LumberJack
              So, for the daily report. I have always the problem that I dont arrive to register my own gpio schematics in Recalbox. By chance vertical axe from standard Recalbox is the same in Freeplay, so this works. And with sdl2-jstest he show me :
              Joystick Name:     'GPIO Controller 1'
              Joystick Path:     '/dev/input/event2'
              Joystick GUID:     15000000010000000100000000010000
              Joystick Number:    0
              Number of Axes:     2
              Number of Buttons:  9
              Number of Hats:     0
              Number of B***s:    0
              GameController:
                not a gamepad
              Axis code  0:    0
              Axis code  1:    1
              Button code  0:   304
              Button code  1:   305
              Button code  2:   307
              Button code  3:   308
              Button code  4:   310
              Button code  5:   311
              Button code  6:   314
              Button code  7:   315
              Button code  8:   316
              In /etc/modprobe.d I have mk_arcade_joystick,conf (and also under name mk_arcade_joystick_rpi.conf this line
              But I dont arrive to register in /dev/input/js0.
              Also if I indicate in recalbox.conf map=4, what should be legal after the github description
              # ------------ D2 - GPIO Controllers ------------ #
              ## GPIO Controllers
              controllers.gpio.enabled=1
              controllers.gpio.args=map=4
              Recalbox dies with kernel panic, this should be an issue in Recalbox.
              So, my only chance, I think, to redefine it under map=1. That's it for the moment.
                @dragu said in Freeplay CM3 GBA clone Kit.:
                this is what you'd add in te line. But:
                1. not yet handled
                2. our KO doesn't handle custom mappings. this is why told you i'd compile one for you
                • Dragu
                  @Substring
                  Thanks, that is an answer. The problem, github is a horror of software version management, you dont find no old sources. In the Freeplay support files that are inside the .IMG release, I have the latest source versions from him also with hotkey modifications. If it could help you :
                  http://zclub.eu/Freeplayhome.7z
                    it's the best one ever, trust me. You just need ot learn how to use it.
                    Here is an upgraded hk version of the driver. Use map=5 gpio=4,17,6,5,19,26,16,24,23,18,15,14,20,-1
                    https://we.tl/hLeKAomdIy
                    • Dragu
                      Dragu Banned last edited by acris
                      @Substring
                      So quick ? Thanks alot for your work, I will give feedback in short.
                      In between one picture from my testing place, Hub with keyboard and Wifi stick, HDMI mini to HDMI-HDMI to VGA adapter and power supply 😉
                        @dragu sexy !
                        • Dragu
                          @Substring
                          I am on the way to reload the system after the crash. Also concerning mk_arcade_joystick_rpi, there is some confusion about the file in /etc/modprobe.d
                          Described in github is mk_arcade_joystick.conf, but it seems that mk_arcade_joystick_rpi.conf is the good one, as what you read in the web. Logical, no ?
                          • Dragu
                            @Substring
                            There is no crash anymore with map=5 in recalbox.conf. Concerning mk_arcade_joystick_rpi.ko, I tried out with both versions of the .conf file in /etc/modprobe.d, but evtest fails to find a controller. 🙂
                              @dragu check with lsmod if it's loaded + don't load it through recalbox.conf, it doesn't take all parameters. rmmod the ko, then manually modprobe it with your parameters
                              • Dragu
                                @Substring
                                Hi friend, in lsmod the driver is not existing (was there before) and with modprobe I have following feedback
                                # # modprobe mk_arcade_joystick_rpi map=5
                                # modprobe: can't load module mk_arcade_joystick_rpi (extra/mk_arcade_joystick_rpi.ko): Invalid argument
                                • Dragu
                                  @Substring
                                  Some more small info. If I put him map=1 (I suppose same with 1,2) in recalbox.conf, the driver is loaded correctly as with the version before and also same behavior.
                                    @dragu have a look at /recalbox/scripts/recalbox-config.sh line 448 for loading the module and add your parameters
                                    • Dragu
                                      @Substring
                                      Hi, I just made some tests. So if I define in recalbox.conf map=5, he just dont load mk_arcade_joystick_rpi.ok and if I put there map=1, he load object but also with the standard gpio definition.
                                      As you told I changed in recalbox-config.sh the following
                                      if [ "$command" == "gpiocontrollers" ];then
                                          command="module"
                                          mode="load"
                                          extra1="mk_arcade_joystick_rpi"
                                          extra2="map=1,2"
                                      to
                                          command="module"
                                          mode="load"
                                          extra1="mk_arcade_joystick_rpi map=5 gpio=4,17,6,5,19,26,16,24,23,18,15,14,20,-1"
                                          extra2="map=1,2"
                                      I tried with and without map=5, but perhaps I made a mistake here ?
                                      Anyway recalbox.conf seems to have bigger influence, as with map=5 there, he even dont load the object.
                                        @dragu better summon @ian57 here, he made the tests with gpio remapping
                                        • Dragu
                                          @Substring
                                          @ian57 was last here 12 days ago, so I return to my cave 😉
                                          With PiGRRL the problem of the custom GPIO may also exist.
                                          Substring ian57 2 Replies Last reply Reply Quote 0
                                            @dragu but i can get in touch with him almost whenever i want 😉
                                            100.6k
