    Cant you install and configure recalbox on a usb drive?
    cant configure recalbox usb
    • nate009
      nate009 last edited by
      Hi Guys
      I have installed recalbox on a usb drive and successfully booted which is great but when i plug the drive into my mac to view the contents and update it, i cannot see a dir to place my roms?
      I only get an EFI folder and a BOOT folder?
      Am i missing a trick?
        Substring @nate009 last edited by
        @nate009 you're missing that it's a linux system and uses some filesystem format that a mac can't read
        • nate009
          I found that you need to connect the device to the network to see the network share, then i could copy my games 😄
          • leprive
            leprive last edited by
            Just for info, there exists software to enable reading/writing on ExtFS partition (like the one with the roms for recalbox).
            I've tried the trial version (30 days I think) of the one called extFS by Paragon. It works perfectly. I think the full version is approx 40$
            There are free software that permits also to do that, namely OSXFuse but it seemed a bit less user friendly, I did not try it.
